soypp123 Occasional Visitor
Posted: Thu Feb 10, 2005 7:50 pm Post subject: ¿Map version? |
Is ther a way to know the date or version or a Tom Tom Navigator or Go map?
I have TT3 and a friend has just bought TT Go, and we would wont to know who has the most up-to-date map!
best regards |
BoPeep Pocket GPS Moderator
Joined: 14/03/2003 22:46:42 Posts: 953 Location: Oxfordshire, England, United Kingdom
Posted: Thu Feb 10, 2005 8:31 pm Post subject: |
Hola soypp123,
On TomTom Navigator, if you go to 'File' and 'About' when you are in Map mode this should tell you the version number and also the year that the data was produced.
Hope this helps.
¡Buena suerte!
Bo Peep. _________________ TomTom 730
HTC Desire - Co Pilot Live Premium (Europe) |
Posted: Fri Feb 11, 2005 6:09 pm Post subject: thanks |
many thanks/gracias |
Posted: Fri Feb 11, 2005 7:35 pm Post subject: latest map (not program) releases |
Does TomTom reports which is the latest version published for their map by country? I cant find any info on their website!
Thanks |
xcntalien Occasional Visitor
Joined: Jan 08, 2005 Posts: 8 Location: North Staffs, UK
Posted: Sat Feb 12, 2005 8:32 pm Post subject: |
When I do "File", About" on my TomTom Navigator install (in map mode) I get : 3.01 (409).
Does "409" mean "2004, September" ?
Stuart. |
xda Lifetime Member
Posted: Sun Feb 13, 2005 3:00 am Post subject: |
xcntalien wrote: | When I do "File", About" on my TomTom Navigator install (in map mode) I get : 3.01 (409).
Stuart. |
That means your on release 3.01 build 409
The latest is 3.07 build 442 _________________ Graham.
Map: Europe V910.4892
Nokia 925 Windows 8 |
Posted: Mon Feb 14, 2005 1:56 pm Post subject: Only the soft verison. |
Bo Peep wrote: |
On TomTom Navigator, if you go to 'File' and 'About' when you are in Map mode this should tell you the version number and also the year that the data was produced. |
It seems that the ver. displayed is the program and build version, not the map data version.
Am I wrong?
Regards |
DavidW Pocket GPS Moderator
Posted: Tue Feb 15, 2005 4:12 am Post subject: |
It's program version and (program) build. I don't know of any way to access the map version in Navigator 3 short of looking at the third line of the .pna file in the map folder.
In Navigator 2004 HP Edition and other TomTom "common platform" software then, from memory, there's an easier way of accessing map version data. However, I've got Navigator 3 installed on the iPAQ to my right at the moment, and I'm not going to change it to 2004 HP Edition just to check!
David |
Posted: Sun Feb 27, 2005 9:35 pm Post subject: my version |
by opening in notepad the .pna file, i know the release of my map is ver 290, while my friend TomTomGo map is ver 390. Sneaking into Spanish forums, seems that 390 is the most advanced release for Spain maps. Dont know about other countries though.
Best Regards |
lbendlin Pocket GPS Staff
Posted: Sun Feb 27, 2005 10:40 pm Post subject: |
390 is not a release number. It is the number of the map compilation, and a higher number does not necessarily mean that map cut is better. Quite contrary, we have seen a number of cases where newer map cuts had disastrous routing issues and map display errors.
Having said that, 390 seems to be relatively stable. But we all hope for a new cut with the CeBit announcements. _________________ Lutz
TomTom/TeleAtlas NAVTEQ |
Posted: Tue Mar 01, 2005 7:44 pm Post subject: |
not withstandig the posibility of errors, a newer compilation (higher number?) should be made from fresher data. or...is there other rationale at TomTom headquarter that evades my understanding?
thanks and best regards
PS:hoping also for a fresher cut at Cebit |
Posted: Tue Mar 01, 2005 9:24 pm Post subject: |
Users may have reported routing errors, TomTom have then tweaked the calculation formulae, only to make it worse etc... _________________ Lutz
Posted: Tue Mar 01, 2005 9:54 pm Post subject: |
but the calculation formulae should be part of the program, changing only in new PROGRAM RELEASES (3.0, 3.01, 3.07...) and not in new DATA releases (290,314,390...).
Or, is the routing algorithm included in the map (not Program) files?
mmm, interesting! 8O |
