Pocket GPS World :: View topic - Can I be guided to a co-ordinate rather than an address ????
craigaucott
PostPosted: Tue Mar 01, 2005 10:46 am    Post subject: Can I be guided to a co-ordinate rather than an address ???? Reply with quote
Is it possible to set a co-ordinate as your destination in SmartST ??? (eg. N 51° 18.121 E 000° 34.366)
I can only see options for addresses or POI's.
The other option would be to set a POI at that co-ordinate, but can you do this ???
I have only had the software since yesterday, and have not found out a way to do it yet.
uffe73
PostPosted: Tue Mar 01, 2005 11:02 am    Post subject: Re: Can I be guided to a co-ordinate rather than an address Reply with quote
No, you cannot get routing to a long/lat position in SmartST. Hopefully this feature will appear in V4!
TomTom GO720T: App ver 8.351(9982/090518), OS:315187, GPS v1.20, Boot 5.5120
TT RDS-TMC: 4V00.013
Maps: Scandinavia v840.2562, Western_Europe v715.1703
Garmin GPSMap 60CSx (SW ver. 3.70)
craigaucott
PostPosted: Tue Mar 01, 2005 11:05 am    Post subject: Reply with quote
OK.
Thanks Uffe.
I'll have to see if any other software will do it.
Tim Buxton
PostPosted: Tue Mar 01, 2005 11:31 am    Post subject: Re: Can I be guided to a co-ordinate rather than an address Reply with quote
As Ulf says, you can't (yet) route to a set of coordinates , nor can you create a POI at a set of coordinates on the device. However, if you have the time, you can create POIs on the Desktop software using the POIEditor and then transfer them to the device. On the PPC version then you have to have the device connected to be able to use the POIEditor, though. I assume, but don't know definitely if, the iCN series are the same.
Tim
kartracer
PostPosted: Tue Mar 01, 2005 12:09 pm    Post subject: Reply with quote
Another option, if you have a registry editor, is to create a favourite... it doesn't matter where. You can then edit the registry key containing the Latitude and Longitude for that favourite.
e.g.
HKEY_LOCAL_MACHINE\SOFTWARE\Navman\Smartst Pro\Favourites\Items\Keyed\KFAVNAME\Latlong
where FAVNAME is whatever you called your favourite.
Kam
craigaucott
PostPosted: Tue Mar 01, 2005 5:14 pm    Post subject: Reply with quote
If I did that, what would SmartST do once I got off-road ???
Will it tell me the direction I need to travel, or will it try to send me back to the nearest "acceptable" road ???
Would it give me a pointer, or say "Continue for XX metres in *This* direction" ???
kartracer
PostPosted: Tue Mar 01, 2005 5:28 pm    Post subject: Reply with quote
It won't take you off-road. If it thinks you are off-road it will just tell you to drive to the nearest road.
Kam
Stefan
PostPosted: Tue Mar 01, 2005 10:19 pm    Post subject: Reply with quote
It sounds like you might want to consider a different GPS package. For 'off road' and co-ordinates have you considered Memory Map?
Stefan
BBB
PostPosted: Wed Mar 02, 2005 5:51 pm    Post subject: Reply with quote
Can Memory Map do both?
Does it have a timeloaded demo?
icsys
PostPosted: Wed Mar 02, 2005 6:44 pm    Post subject: Reply with quote
All the topographical software packages, which are ideal for 'off road' wether it be driving or walking, have demos.
Check out www.memory-map.co.uk www.anquet.co.uk www.fugawi.com
Ian.
Navman iCN 635
TomTom GO
Anquet OS mapping
BBB
PostPosted: Thu Mar 03, 2005 1:36 am    Post subject: Reply with quote
The one that is attracting my attention at the moment is a Microsoft Product Street & trips 2005
Apparently compatible with PC, PPC and smartphones
No more of this snagged in silly stupid programing
In a way I can't wait for my maps to be outdated
Groovy!
ps - streetwise I mean I don't think MS do topo (yet?)
icsys
PostPosted: Thu Mar 03, 2005 8:15 pm    Post subject: Reply with quote
Have you seen the maps on Streets and Trips? (which is the US version by the way)
If you look at Autoroute (EU version) maps they are nowhere near as good as Navman or TomTom. And it does not provide voice guidance or any guidance for that matter. It merely plots your position on the map.
Don't get me wrong, it works and is pretty accurate but it is no substitute for a proper sat nav product.
Ian.
Navman iCN 635
TomTom GO
Anquet OS mapping
BBB
PostPosted: Thu Mar 03, 2005 9:12 pm    Post subject: Reply with quote
I guess there had to be a catch in it
Thanks icsys
SamOntario
PostPosted: Fri Mar 18, 2005 8:56 pm    Post subject: Reply with quote
Groovy!
Streets & Trips 2005 has advantage of very updated map data and very easy to locate the address on laptops. Problem - it has no sound as someone already indicated.
On PPC, when exporting maps to PPC, each map is limited to below 5 MB, i.e. within 30 minutes drive, you need to change maps and there is no way you can merge the maps. Its only good when you are in that city.
SamOntario
PostPosted: Fri Mar 18, 2005 9:01 pm    Post subject: Reply with quote
Forgot to mention, for PPC, there are already main city maps around the world for free download.
