Pocket GPS World :: View topic - Please help
Please help
psyber
PostPosted: Sat Feb 26, 2005 7:25 pm    Post subject: Please help Reply with quote
I have just purchased an iPAQ 1930 with Alturion and a Globalsat br-305 with AH-103 connector. But the Alturion software does not have the br-305 in the dropdown list of receivers (unless it goes by another name?). I have tried the wizard to search for the receiver but it can never find it.
Just keep getting message - GPS device not connected.
Now I think the receiver is meant to transmit via the IR connection.
I just can't seem to get it working.
Any help appreciated.
Thank you
lbendlin
PostPosted: Sat Feb 26, 2005 10:43 pm    Post subject: Reply with quote
Infrared is normally COM2
Lutz
TomTom/TeleAtlas NAVTEQ
DavidW
PostPosted: Sat Feb 26, 2005 11:01 pm    Post subject: Reply with quote
Or COM3 on some iPAQs - it depends a little on the model.
psyber
PostPosted: Sat Feb 26, 2005 11:30 pm    Post subject: Reply with quote
I have tried both 2 and 3 with all board settings and still no joy Sad
When I try sometimes I have a constant light on the reciever and sometimes it is flashing, what does this mean?
psyber
PostPosted: Sun Feb 27, 2005 3:10 am    Post subject: Reply with quote
I have it working. If anybody else needs the info. COM2, board 4800. and untick receive all IR from the beam settings.
EasyD2
PostPosted: Mon Mar 14, 2005 10:54 am    Post subject: Reply with quote
The setup instructions are actually included with the AH-103 mount. But just to recap...
1. Make sure the infra red module is in line with the infra red of your PDA.
2. Go to settings / connectivity / beams and untick "Receive all incoming beams"
3. Start up your Alturion software and it will usually detect your GPS Receiver automatically, but if it doesn't then choose "NMEA 4800" and Com 2.
www.easydevices.co.uk
Tel: 0871 7000 156
Globalsat UK Distributor
psyber
PostPosted: Wed May 04, 2005 11:29 pm    Post subject: Reply with quote
thanks for all the info. Now it has been working ok since i gt it, but just recently evn with all the correct settings, it can't seem to find the GPS Device. It found it tonight on my way to somewhere. But on the way back it just would not connect. I tried the wizard. I reset the PDA, checked all the settings, it all seems fine. but it just won't find it. Is it possible I have a dodgy one?
EasyD2
PostPosted: Thu May 05, 2005 11:02 am    Post subject: Reply with quote
The infra red module has a flat end and a curved end. Can you make sure the curved face is pointing towards the infra red of the PDA.
Is the PDA failing to find the GPS Receiver or is the GPS Receiver not finding satellites?
Tel: 0871 7000 156
psyber
PostPosted: Thu May 05, 2005 1:24 pm    Post subject: Reply with quote
mm good question
I tried it this morning at home and it seemed to pick up 5 out of 12 satelites. I was using the the GPS info that comes with Alturion. Not sure if you are familiar with it but you get like a pulse line, it was mainly red, sometimes flashed blue. went green for a few seconds then stayed red. then the light on the gps device stayed constant.
Are there any software drivers for this device?
EasyD2
PostPosted: Thu May 05, 2005 2:47 pm    Post subject: Reply with quote
I'm not getting a clear picture here.
You said you tried it at home... how did you get the infra red mount to work at home...?
Tel: 0871 7000 156
psyber
PostPosted: Thu May 05, 2005 3:08 pm    Post subject: Reply with quote
I have an adapter.
psyber
PostPosted: Thu May 05, 2005 6:27 pm    Post subject: Reply with quote
I now don't even get a flashing LED anymore. It's just like when I first got it. Either a setting has gone wrong or it's knackered.
22.055 (29 May 24)
