Pocket GPS World :: View topic - Rikaline Bluetooth GPS
Filler
PostPosted: Sat Feb 26, 2005 12:00 am    Post subject: Rikaline Bluetooth GPS Reply with quote
Question
I have been using my wired tomtom gps for a while, and have decided to go mobile, by using a Rikaline slimline bluetooth GPS reciever, with TT3 and my ipaq 2210.
http://www.rikaline-uk.co.uk/navigation/rikaline.html
However every 10 minutes or so, i lose GPS signal, and have to go into the GPS status screen and turn the gps off then on in the tick box.
the gps then communicates perfectly for about 10 minutes then the same again,
I have paired the units, charged the batteries, checked every bluetooth setting possible, but it still happens.
However sat here looking through the forums, it has been connected for 30 minutes with 6 sats and no problems.
anyone any ideas.
Nigel
Blackberry Storm
iphone 3gs
Kenwood 5520bt with garmin built in
TT wired GPS - Rikaline Bluetooth 6030 GPS - CF307 CF card GPS - 512mb sd card - sprite full updated, and tt3 , 3.07. 256mb CF card - Win XP SP2 upgrad
DavidW
PostPosted: Sat Feb 26, 2005 5:32 pm    Post subject: Reply with quote
Are you using SD memory for your maps? The reason for asking is that many people have found the combination of iPAQ h2210, TomTom Navigator 3, SD memory for the maps and a Bluetooth GPS unstable. Change any one of those things, and the instability tends to disappear.
For example, I use TomTom Navigator 3, SD memory for the maps, a Bluetooth GPS and an iPAQ hx4700.
Probably the easiest thing is to put your maps on a CompactFlash card. I can't guarantee that it will solve the problem, but it seems to have helped many people.
By the way, you'd inadvertently managed to post the same message twice - I deleted the duplicate.
(Edited: typo in iPAQ model number corrected)
Filler
PostPosted: Sat Feb 26, 2005 7:30 pm    Post subject: hp2210 Reply with quote
Thanks,
i will give it a go and swap my maps over to CF card, i run TT3 from the SD card as well, dont know if this has any bearing.
regards
nigel
Nigel
Blackberry Storm
iphone 3gs
DavidW
PostPosted: Sat Feb 26, 2005 8:40 pm    Post subject: Reply with quote
It might help if you put the TomTom Navigator application in main memory - you can only experiment.
I'd start by moving the map to your CompactFlash card; you can see if that makes things stable.
22.064 (26 Jun 24)
