Pocket GPS World :: View topic - Deleting foreign voices
atters
PostPosted: Thu Feb 03, 2005 2:50 pm    Post subject: Deleting foreign voices Reply with quote
Sad
I have a TTG with the 128Mb SD card supplied. I would like to delete the non English voises from the card to make space for the safety camera data files. Can anybody advise on which files I can delete and where they can be found?
Atters
hemantp
PostPosted: Thu Feb 03, 2005 2:54 pm    Post subject: Reply with quote
You can use the CD provided with the TTG... hook it up via the USB cable provided with your PC. And you'll see the option to add/remove the voices.
.h
a l w a y s a p l e a s u r e . . .
. . . n e v e r a c h o r e
boris
PostPosted: Thu Feb 24, 2005 12:43 am    Post subject: Reply with quote
Hi.
I deleted the foreign voices and that clears plenty of space - BUT - not enough space if you then find you want to add on the postcode search which is REALLY useful. So, just bought a Kingston 512MB card, and hope to get it all swapped over. (Just found out I need a reader/writter before I can do that though). I suppose point is, I think you may well end up using a 'bigger' card anyway...
PostPosted: Thu Feb 24, 2005 7:53 am    Post subject: Reply with quote
No, you don't need a reader.
Connect TTG to PC, as detailed in handbook, and drag all the contents of the 128 card to a temp folder on the PC.
Switch off TTG, swap cards, switch on TTG and copy every thing from the PC back to the card. That way you won't have to activate again.
boris
PostPosted: Thu Feb 24, 2005 10:08 pm    Post subject: Reply with quote
Hi.
Oldboy you are a true TomTom GOD!! :P
Trouble is, just before comming on the forum tonight I ordered a reader from Dabs!!!! I read your reply, and the laptop is now busy copying in the way you advised! MAGIC can't thank you enough.
Now I will have ALL cameras, and hopefully due to the Kingston 512, ALL postcodes. Sorry for my muppetry Embarassed
boris
Privateer
PostPosted: Thu Feb 24, 2005 10:26 pm    Post subject: Reply with quote
Hi Boris,
Don’t worry about buying the card reader. I would expect that you can transfer data much quicker via a card reader than via the TTGO.
I can copy/write nearly 1GB of data to and from a CF card in just over 4 minutes. Before I had a card reader, installing a map of 100MB via MS ActiveSync would take about 20 to 25 minutes.
Robert.
Garmin Camper 770 LMT-D
PostPosted: Thu Feb 24, 2005 10:38 pm    Post subject: Reply with quote
Privateer wrote:
Hi Boris,
To install the France Map on to a SD card while in the TTG takes about 22 mins.
I suppose it's down to a question of convenience and choice.
