vanduk Occasional Visitor
Posted: Tue Feb 15, 2005 1:27 pm Post subject: Pocket GPS World Speed Camera Database |
Can anybody tell me if it is possible to display on the TomTom Map and Icon to show Speed cameras? If so how do I do it? |
DavidW Pocket GPS Moderator
Posted: Tue Feb 15, 2005 1:31 pm Post subject: |
If you've put the database files in your map folder, you need to enable the POI in the TomTom software. As you haven't said which version of TomTom software you're using, I'll guess at Navigator 3 on the Pocket PC. For that, you go to File -> Properties, and select the files you want displayed on the POI tab.
David |
Posted: Thu Feb 17, 2005 12:26 am Post subject: Speed Camera Database |
David, Yes it is TT3 and I have downloaded the Speed camera database and have the Speed camera in POI list however there is no Icon shown against this. It has been given a cross like a couple if other POI's which are displayed on the Map, however however there is no Icon for the Speed camera shown on map. I get warning the warning sound signals Ok. I would like to see Speed camera Icons on the Map if possible.
Ivan |
Posted: Sun Feb 20, 2005 8:26 pm Post subject: |
You need to copy both the .ov2 (data) and .bmp (icon) for each category you want to display to your map folder.
Exit TomTom Navigator (or soft reset) and restart it once you've done that, and you should then have the icons.
David |
Posted: Sun Feb 20, 2005 9:46 pm Post subject: |
David,
Many hanks for your help.
Ivan |
Posted: Wed Feb 23, 2005 12:11 am Post subject: |
David,
Sorry to trouble you again. Where do I get the Speed Camera .bmp(Icon) file from.
Ivan |
Posted: Wed Feb 23, 2005 12:39 am Post subject: |
There should be .bmp files corresponding to all the .ov2 files in the Speed Camera Database .zip.
If you install the files using POIEdit and the POI Sync service, that should install the .bmp files from the server.
David |
Posted: Thu Feb 24, 2005 12:17 am Post subject: |
David,
Many thanks for your help.
Ivan |
xda Lifetime Member
![](modules/Forums/images/avatars/2206758954c7fc3ddae53f.jpg)
Posted: Thu Feb 24, 2005 3:30 am Post subject: |
David, POIEdit and the POI Sync Service will not download the Speed related Gatso, Mobile .ov2 and .bmp files. They seem to only be available by directly downloading the complete Pocketgps Speed Camera database Zip archive. _________________ Graham.
Map: Europe V910.4892
Nokia 925 Windows 8 |
Posted: Fri Feb 25, 2005 8:06 pm Post subject: |
That's a "known issue" at present. Adding the 'speed categorised' files requires POI Sync to be reworked a bit; that should hopefully be done fairly soon.
David |
xda Lifetime Member
Posted: Sat Feb 26, 2005 3:30 am Post subject: |
Ok David, Thanks for that. _________________ Graham.
