Dave Frequent Visitor
![](modules/Forums/images/avatars/92698813943397cac09a13.gif)
Posted: Sun Sep 14, 2003 8:04 am Post subject: TTN2 Post your fault here!!! |
TomTom have now released an update to hopefully fix this problem. Please check here for more information. |
3GGG Frequent Visitor
![](modules/Forums/images/avatars/17760598104a688f2ac95cb.jpg)
Joined: 26/09/2002 13:55:07 Posts: 269 Location: United Kingdom
iPAQ 3870
Holux GM-210
Properties:Advanced:Map view - Show Favourites setting not retained after restart. ( I set it to not show favourites and later it is back on again).
Navigate to a favourite - the final instruction says for example - " Arrive at (UUnnmed location) (Coldstream (The Scottish Borders)) when in fact the final destination has a name (set in favourites) and is not anywhere remotely near the Scottish Borders.
[That is how it spells 'unnamed'] _________________ David |
Compaq iPAQ 3850
Leadtek 9531
No problem found |
Decker Occasional Visitor
Compaq IPAQ 3870
Emtac BTGPS
Tells me to drive on the wrong side of the road and to take roundabouts in wrong direction, frekvent lockups and slow operation.
Decker |
ottopop Occasional Visitor
Toshiba 740 BT
Emtac GPS BT
During a trip to a city who is 100 km far from where I live I tried to let navigator 2 calculate an alternative route... The PPC crashed |
Darren Frequent Visitor
Compaq iPAQ 3630
Navman 3000
No problems _________________ Darren Griffin |
Mark R Penn Regular Visitor
Joined: 10/09/2002 17:13:17 Posts: 176 Location: United Kingdom
HP iPaq 5450
Teletype serial mouse
No problems except can't always save favourites with tap and hold. _________________ If you choose not to decide, you still have made a choice. |
musicreative Regular Visitor
Joined: 15/01/2003 16:48:43 Posts: 100 Location: United Kingdom
Compaq iPAQ 3970 (ROM 2.0)
Emtac BTGPS
Unstable, frequent crashes and lock-ups, especially in Navigator screen and favourites.
Tim |
RichDem Frequent Visitor
![](modules/Forums/images/avatars/gallery/avatar_ani_015.gif)
Joined: 12/12/2002 11:57:47 Posts: 259 Location: East Yorkshire
Compaq Ipaq 3950 (ROM 1.00)
Leadtek 9532
Unable to save to favourites with tap & hold feature, problems navigating to any favourites especially "Home"
Richard |
xjt00 Occasional Visitor
Joined: 04/04/2003 13:44:05 Posts: 10 Location: United Kingdom
Dell Axim X5 300Mhz (RON A00 (11110200EN)
Holux GM-270 CF
Definitely lock up when planning the route second times to some specific roads (as far as I tested) saved in Favourits; unable to tap and hold to set as Departure/Destination on some roads. _________________ XJT |
For everyone that is having problems, please post the - Pocket PC you have
- GPS Receiver you are using
- One line describing fault that occurs
For those who aren't seeing a problem again, please post the - Pocket PC, GPS Receiver you are using
This will help us collate these problems as there are too many threads being created and it's hard to track.
PLEASE DO NOT POST ANY COMMENTS HERE, JUST HARDWARE!!! |
georg Occasional Visitor
Joined: 12/12/2002 23:48:50 Posts: 2 Location: United Kingdom
HP Jornada
Leadtek 9531
No Problems....so far
Georg |
Talkingbollox Frequent Visitor
![](modules/Forums/images/avatars/1669536683418e9e94aaf72.gif)
Joined: 14/10/2002 15:11:34 Posts: 439 Location: United Kingdom
iPaq 3870
No receiver connected
Software goes into initial "frame" grey screen then crashes, leaving the GPS application running. |
iancjc Frequent Visitor
![](modules/Forums/images/avatars/avatar_sp_034.jpg)
Joined: 10/02/2003 14:19:44 Posts: 749 Location: United Kingdom
ipaq 3850 cf+ sleeve (rom 1.2) maps on a 128mb sd card
pretec cf-gps lp card
no problems running the software - issues with how it operates! |
johndglynn Occasional Visitor
Joined: 04/03/2003 16:21:53 Posts: 14 Location: United Kingdom
iPAQ 3970 with 256 SD
Emtac BTGPS
Safety Screen blinking from just mph display to full info screen. When I eventually slow down and switch back to map I get 'GPS unreliable', despite an 8 sat fix on the Emtac, what a joke. |
