Pocket GPS World :: View topic - Viftool - Customized POI alerts sounds
cdelecole
PostPosted: Wed Feb 16, 2005 2:16 pm    Post subject: Viftool - Customized POI alerts sounds Reply with quote
Hi there !
Do you know whether it is possible to create your own POI warning sounds, instead of the predefined, on a TOMTOM GO ?
Do you know if Viftool can do that ?
Thanks !
PostPosted: Wed Feb 16, 2005 2:31 pm    Post subject: Reply with quote
The warnings are talked about here:
http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=16489&postdays=0&postorder=asc&start=30
I don't know if that's the information you want.
cdelecole
PostPosted: Wed Feb 16, 2005 2:57 pm    Post subject: Reply with quote
I've tried that, but that was not working for me (Instead, default sounds were always played when testing the POI alerts).
Did somwone tested the full path from creating his own sound file, and associated it to the POI he wanted ?
Thanks !
PostPosted: Wed Feb 16, 2005 4:05 pm    Post subject: Reply with quote
What I did was rename data.chk to data._hk, then copied 2852_ etc to the same folder on the SD card - and renamed it.
If you are still getting the same warnings it's possible that if you did not rename, or delete, the original data.chk the renaming of the new file was not completed.
Make sure there is no data.chk file in the folder before renaming and/or copying.
Does that help/make sense
22.062 (12 Jun 24)
