Pocket GPS World :: View topic - External antenna - does it compliment or replace built in 1?
ipaqczar
PostPosted: Mon Feb 14, 2005 9:13 pm    Post subject: External antenna - does it compliment or replace built in 1? Reply with quote
Hey gang,
I have a CF BC-307 and it has the jack for the external antenna- which I am starting to use a little more because I do get some better results.
My question is - once I plug in the external antenna - are all the signals coming in through that - or does it receive signals from both the external and built in antennas?
I have my ipaq 3950 & the CF BC-307 on the dash - and then I run the external antenna to the back window of the car - and thus I assume I am getting signals in the front and the back fo the car.
But if the built in antenna isn't used when the external is plugged in - then I guess I should just have the external up front as well.
PostPosted: Mon Feb 14, 2005 9:28 pm    Post subject: Reply with quote
the internal antenna is switched off completely as soon as you connect the external antenna.
22.064 (26 Jun 24)
