Spies Occasional Visitor
Posted: Mon Feb 14, 2005 9:12 am Post subject: TomTom Startup Freezes |
I've got a IPAQ RX3715 connected to a Road Angel which supplies the GPS data, now I have a problem whereby upon restarting TomTom it just hangs at the spinning disc or the application fails to start at all. I'm currently running 3.01 and wondered if anyone has any suggestions/fixes for this problem. The only way to make it work again is to soft reboot the IPAQ.
Thanks in advance |
alix776 Pocket GPS Moderator
![](modules/Forums/images/avatars/6212487444319be6786243.jpg)
Posted: Mon Feb 14, 2005 9:19 am Post subject: |
try upgrading to 3.07 and see if that helps maybe reinstalling the map to the storage card might work to _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
device Lumia 950 xl |
Posted: Mon Feb 14, 2005 9:23 am Post subject: |
I've tried 3.07, the spinning disc appears and stays there. With 3.01 nothing happens when you application is opened.
What GPS driver does 3.01 use? |
Posted: Mon Feb 14, 2005 10:17 am Post subject: |
have you any other programs running in the bacjground tt usually wont run if the calender is open in the background
try a softreset then run tt if not completely remove tt then reinstall try loading a small map section on the ppc itself if it works delete the storage card format it then reistall the uk map to the storage card _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
Posted: Mon Feb 14, 2005 11:23 am Post subject: |
There were no other programs running.
I've tried reinstalling a couple of times, what do you mean by a small map section, I only have the UK Maps. |
Posted: Mon Feb 14, 2005 11:24 am Post subject: |
Just to make clear, It's does work, it just intermittantly doesnt start up. |
