Pocket GPS World :: View topic - TomTom Startup Freezes
Spies
PostPosted: Mon Feb 14, 2005 9:12 am    Post subject: TomTom Startup Freezes Reply with quote
I've got a IPAQ RX3715 connected to a Road Angel which supplies the GPS data, now I have a problem whereby upon restarting TomTom it just hangs at the spinning disc or the application fails to start at all. I'm currently running 3.01 and wondered if anyone has any suggestions/fixes for this problem. The only way to make it work again is to soft reboot the IPAQ.
Thanks in advance
alix776
PostPosted: Mon Feb 14, 2005 9:19 am    Post subject: Reply with quote
try upgrading to 3.07 and see if that helps maybe reinstalling the map to the storage card might work to
device Lumia 950 xl
Spies
PostPosted: Mon Feb 14, 2005 9:23 am    Post subject: Reply with quote
I've tried 3.07, the spinning disc appears and stays there. With 3.01 nothing happens when you application is opened.
What GPS driver does 3.01 use?
alix776
PostPosted: Mon Feb 14, 2005 10:17 am    Post subject: Reply with quote
have you any other programs running in the bacjground tt usually wont run if the calender is open in the background
try a softreset then run tt if not completely remove tt then reinstall try loading a small map section on the ppc itself if it works delete the storage card format it then reistall the uk map to the storage card
device Lumia 950 xl
Spies
PostPosted: Mon Feb 14, 2005 11:23 am    Post subject: Reply with quote
There were no other programs running.
I've tried reinstalling a couple of times, what do you mean by a small map section, I only have the UK Maps.
Spies
PostPosted: Mon Feb 14, 2005 11:24 am    Post subject: Reply with quote
Just to make clear, It's does work, it just intermittantly doesnt start up.
