lbendlin Pocket GPS Staff
![](http://www.pocketgpsworld.com/modules/Forums/images/Caricature-Lutz.png)
Posted: Sun Feb 06, 2005 5:17 pm Post subject: |
Depends on what exactly you want to achieve. Have a look at thee NMEA data - most of the lines are fixed length so you can extract the required fields easily.
The coordinates are stored as (D)DDMM.MMMMM and you have to recalculate this to convert them to decimal degrees. There are tons of conversion utilities and code snippets on the web. _________________ Lutz
TomTom/TeleAtlas NAVTEQ |
kin Occasional Visitor
Posted: Mon Feb 07, 2005 4:10 pm Post subject: |
lbendlin wrote: | Depends on what exactly you want to achieve. Have a look at thee NMEA data - most of the lines are fixed length so you can extract the required fields easily.
The coordinates are stored as (D)DDMM.MMMMM and you have to recalculate this to convert them to decimal degrees. There are tons of conversion utilities and code snippets on the web. |
thanks alot |
Posted: Thu Feb 10, 2005 5:03 pm Post subject: |
hi,
the VisualGPSce software is able to log nmea file,can the information be saved to a database? eg to SQL SERVer CE??
Thanks a million.... |
Posted: Thu Feb 10, 2005 5:26 pm Post subject: |
If you want to do that you can write a quick program yourself - the Embedded Visual Tools are freely available - knowledge in c/c++ is required though.
You would not need VisualGPSCE then - the program could write the stream directly into the database _________________ Lutz
Posted: Fri Feb 11, 2005 1:35 pm Post subject: |
lbendlin wrote: | If you want to do that you can write a quick program yourself - the Embedded Visual Tools are freely available - knowledge in c/c++ is required though.
You would not need VisualGPSCE then - the program could write the stream directly into the database |
thanks lbendlin,
i would like to ask is there any recommended website that i can reference to?
thanks..... |
Posted: Sat Feb 12, 2005 2:25 pm Post subject: |
lbendlin wrote: | http://www.pocketpcdn.com/libraries/franson_gpstools.html |
i have gone to the websitethat you have recommended. however, the website doesnt mention about saving the gps location to the database i also found out that,in order to use all the service, need to buy the license. is there other freeware available elsewhere? thanks for your help |
Posted: Sat Feb 12, 2005 3:03 pm Post subject: |
This was just an example - of course you can also write this yourself.
But you must accept the fact that you may actually need to do something - what you want has not yet been done, so you need to learn how to program , how to parse NMEA strings, how to control a database etc.
Whichever way you choose - there is a cost. Either you pay for licenses or you invest your time. _________________ Lutz
Posted: Sat Feb 12, 2005 3:53 pm Post subject: |
lbendlin wrote: | This was just an example - of course you can also write this yourself.
Whichever way you choose - there is a cost. Either you pay for licenses or you invest your time. |
okay thanks... |
