zappy61 Regular Visitor
Joined: 21/03/2003 08:28:05 Posts: 72 Location: United Kingdom
Posted: Sun Feb 06, 2005 7:20 am Post subject: Losr USB connection |
Can anyone help. I have used USB connection for my cradle and 3970 for 18 months. Suddenly I lose the connection. I have tried soft reset, configuring the connection settngs to usb and checked the cable but to no avail. However, I can connect using COM1 which I can't work out am I missing something in the settings? _________________ Graham |
lbendlin Pocket GPS Staff
Posted: Mon Feb 07, 2005 5:30 am Post subject: |
USB connection to where ? to the PC ? or do you have a USB GPS receiver? In that case, do you have a serial to USB converter cable? _________________ Lutz
TomTom/TeleAtlas NAVTEQ |
Posted: Mon Feb 07, 2005 8:50 am Post subject: lost usb connection |
I have lost the usb connection to the pc from the cradle. I can connect via com1 but not usb, it has been fine for 18 months. Ichecked the cable its ok and also the settings in activesync connections on the pda. Any suggestions? _________________ Graham |
Posted: Mon Feb 07, 2005 2:53 pm Post subject: |
I had something similiar after I toyed with Check_Notifications and managed to delete the "wakeup on connection" notification for repllog.exe
Plug in the USB cable, set ActiveSync to USB and then run \windows\repllog.exe on the PocketPC - see if that helps. _________________ Lutz
Posted: Mon Feb 07, 2005 9:39 pm Post subject: lost usb connection |
Sorry Lutz can you explain how I start repllog.exe on the pda? _________________ Graham |
Posted: Mon Feb 07, 2005 10:44 pm Post subject: |
use the file explorer, navigate to \windows, tap on repllog _________________ Lutz
Posted: Tue Feb 08, 2005 9:26 am Post subject: |
Sorry Lutz but I don't seem to have that file, could it be deleted? _________________ Graham |
Posted: Tue Feb 08, 2005 3:02 pm Post subject: |
That would be pretty bad. In this case only a hard reset will help to restore the link (the file itself is in ROM)
Backup the whole Pocket PC, do a hard reset, confirm USB is working, and do a complete restore. _________________ Lutz
Posted: Wed Feb 09, 2005 11:42 pm Post subject: lost usb connection |
Thanks,
I ran the file by using the open path command in windows file explorer. It said 'usb connecting to host' but it still won't connect. Any other suggestions please? _________________ Graham |
Posted: Thu Feb 10, 2005 12:02 am Post subject: |
Reinstall ActiveSync on the host _________________ Lutz
Posted: Thu Feb 10, 2005 11:27 am Post subject: lost usb |
Tried reinstalling activesync with all latest updates to 3.8, made sure pda is set to usb, even turned off firewall, no joy. Still keeps saying verify the connection and if I go next does the same again. I can't get com ports now so I am really stuck. Any more suggestions? _________________ Graham |
Posted: Thu Feb 10, 2005 3:32 pm Post subject: |
no, apart from a hard reset there are no more suggestions. _________________ Lutz
