Pocket GPS World :: View topic - may i know how to NMEA information to laptop
Goto page Previous  1, 2
PostPosted: Sun Feb 06, 2005 5:17 pm    Post subject: Reply with quote
Depends on what exactly you want to achieve. Have a look at thee NMEA data - most of the lines are fixed length so you can extract the required fields easily.
The coordinates are stored as (D)DDMM.MMMMM and you have to recalculate this to convert them to decimal degrees. There are tons of conversion utilities and code snippets on the web.
kin
PostPosted: Mon Feb 07, 2005 4:10 pm    Post subject: Reply with quote
thanks alot
kin
PostPosted: Thu Feb 10, 2005 5:03 pm    Post subject: Reply with quote
hi,
the VisualGPSce software is able to log nmea file,can the information be saved to a database? eg to SQL SERVer CE??
Thanks a million....
PostPosted: Thu Feb 10, 2005 5:26 pm    Post subject: Reply with quote
If you want to do that you can write a quick program yourself - the Embedded Visual Tools are freely available - knowledge in c/c++ is required though.
You would not need VisualGPSCE then - the program could write the stream directly into the database
kin
PostPosted: Fri Feb 11, 2005 1:35 pm    Post subject: Reply with quote
thanks lbendlin,
i would like to ask is there any recommended website that i can reference to?
thanks.....
PostPosted: Fri Feb 11, 2005 3:26 pm    Post subject: Reply with quote
http://www.pocketpcdn.com/libraries/franson_gpstools.html
kin
PostPosted: Sat Feb 12, 2005 2:25 pm    Post subject: Reply with quote
i have gone to the websitethat you have recommended. however, the website doesnt mention about saving the gps location to the database i also found out that,in order to use all the service, need to buy the license. is there other freeware available elsewhere? thanks for your help
PostPosted: Sat Feb 12, 2005 3:03 pm    Post subject: Reply with quote
This was just an example - of course you can also write this yourself.
But you must accept the fact that you may actually need to do something - what you want has not yet been done, so you need to learn how to program , how to parse NMEA strings, how to control a database etc.
Whichever way you choose - there is a cost. Either you pay for licenses or you invest your time.
kin
PostPosted: Sat Feb 12, 2005 3:53 pm    Post subject: Reply with quote
okay thanks...
Page 2 of 2
22.064 (26 Jun 24)
