Pocket GPS World :: View topic - Quest input voltage
Quest input voltage
Berisford
PostPosted: Wed Feb 02, 2005 4:19 pm    Post subject: Quest input voltage Reply with quote
I know the Quest, like most Garmins will work on 12 volts using the supplied speaker / power lead, but what is the voltage supplied to the unit?
I don't require the voice / speaker on my motorcycle so I looking to hard wire it straight into the 12 volt supply, but I suspect it may be stepped down by the Garmin speaker plug.
Anyone know?
DPL
PostPosted: Thu Feb 03, 2005 10:26 am    Post subject: Reply with quote
I believe it be 5v in common with many electronic devices. It ensures a stable voltage even when the car/bike battery is running low or experiencing heavy demand.
If you look at your mains charger plug you'll see that it's output voltage, which is a direct feed to the Quest, is 5v.
Be careful...
