Pocket GPS World :: View topic - Medion PNA100
Medion PNA100
K3FUS
PostPosted: Tue Feb 01, 2005 2:29 pm    Post subject: Medion PNA100 Reply with quote
I have the above PDA with GPS and I use it in a Vauxhall Astra Coupe (51 reg).
I am having problems with it picking up a signal when you first turn it on. Sometimes it'll pick up a signal within 2-3 mins, however other times it won't pick up a signal at all.
Is this due to the car and the type of windscreen it has, or could it be due to other outside influences.
I have noticed that the GPS signal is found quicker if the car/PDA is stationary.
Perhaps I need an external antenna, if so where do I get one from?
icsys
PostPosted: Tue Feb 01, 2005 3:08 pm    Post subject: Reply with quote
I'm not sure if your vehicle has an athermic windscreen or not.
How many satellites does the unit lock onto inside the vehicle when a fix is obtained? do you get more if you stand outside the vehicle?
The likely cause of your problem is the fact that you are moving before your device has a satellite lock. You should always try to obtain a fix whilst stationary wherever possible, trying to obtain one whilst moving can increase the fix time considerably especially if you are in a built up area.
Ian.
iPAQ 2210 | Navman 4100 BT Receiver
Navman iCN 635
TomTom GO
Anquet OS mapping
22.094 (25 Sep 24)
