chrismmm Occasional Visitor
Posted: Fri Jan 28, 2005 6:41 pm Post subject: navman 510 fails to lock to satelite |
Very newbie here so hi to everyone and hope you can advise.Wife just got navman 510, the question is why does it take up to an hour to lock onto the satelites ( even out in the open away from obstructions), when it has locked it seems ok until you power off or loose signal due to obstructions.Then it takes ages to re lock. Is it weather related as it seems worse when it rains.This technoligy seems very temprimental and iffy or is just me or have we got a duff navman 510.
chris |
RedDevil_UK Occasional Visitor
Posted: Fri Jan 28, 2005 6:51 pm Post subject: |
in my opinion, having the very same problem at the moment i would get it swapped.
i had the same problem, but not knowing anyone who had one before... i just thought it was crap
but then a friend bought one too (same make) and from loading his navigation software, it had a satellite lock in seconds.... wow!!! i said, but even more amazing was the fact he was stood next to the window INSIDE the house!!!!
thats when i realised mine was broken. |
hmalan Regular Visitor
Joined: Mar 10, 2004 Posts: 70 Location: Doncaster, South Yorkshire
Posted: Sat Jan 29, 2005 1:19 pm Post subject: |
Recently bought one for the wife, but have been using it myself due to a problem with my own system.
If I have turned the battery off switch on the back off and then obviously turned it on when I am wanting to use it it takes a little longer to get a fix.
But the longest I have had to wait at any time is about 2 - 3 minutes to get a fix.
Recently drove through underpasses in Birmingham, lost fix and regained as soon as I came back out, so it does sound like you may have a problem.
One thing I have noticed is that whilst the voice commands are prompt and ok the actual distance to turn displayed on the screen seems to be some way off.
I have just bought a TT GO to replace my system, so will be interested to see how they compare
Regards
Alan
:D |
Posted: Sat Jan 29, 2005 1:21 pm Post subject: |
Forgot to add, I can also get a fix when sat at my desk in our office, which is one of the upstairs rooms in the house
Regards
Alan |
Dave Frequent Visitor
Posted: Sat Jan 29, 2005 3:48 pm Post subject: |
Chris you may find you have an athermic (UV) coated windscreen. See if it fixes any quicker by holding it outside the car. If it does, you will need a re-rad or change your windscreen/car.
A plug-in re-rad is available for the iCN510 and can be purchased from the Navman shop. |
Posted: Sat Jan 29, 2005 4:03 pm Post subject: |
Dave wrote: | Chris you may find you have an athermic (UV) coated windscreen. See if it fixes any quicker by holding it outside the car. If it does, you will need a re-rad or change your windscreen/car.
thanks for the suggestion but it takes up to an hour outside of the vehicle, I have the same problem standing in the garden with no obstructions, once it is locked it seems ok, it is the initial fix after power on from the front push button (not the power on/off at the back). |
Posted: Mon Jan 31, 2005 1:45 pm Post subject: |
As an update to our problem we exchanged the navman 510 for another, this one is considerably quicker in a fix so it would appear that the first 510 was faulty in some way.As a newbie on this subject I have certainly learnt a lot from this forum and thanks for the assistance given.
chrismmm |
