mallettron Occasional Visitor
Joined: May 19, 2004 Posts: 24 Location: sheffield South Yorkshire England
Posted: Wed Jan 26, 2005 7:21 pm Post subject: MIO 168 - nema output from serial port? |
Hi there, can I use GPSGATE to output the nema data via the activesync port on the MITAC MIO 168?????. I need to feed the signal into my amateur radio transciever for APRS use
Ronnie |
lbendlin Pocket GPS Staff
Posted: Thu Jan 27, 2005 1:26 am Post subject: |
GPSGate seems to support TCP output. Since the ActiveSync connection basically relies on TCP that should be possible. Use PPP_PEER as the partner's address _________________ Lutz
TomTom/TeleAtlas NAVTEQ |
Posted: Thu Jan 27, 2005 9:23 am Post subject: |
Actually I was hoping to output the nema string through the serial port into a Kenwood TH-D7E, and forget about the mapping (just use it for reference), I shall have to try it
Ronnie
DOES ANYONE HAVE PINOUTS FOR TH MIO 168 CONNECTOR???/ |
Posted: Thu Jan 27, 2005 3:03 pm Post subject: |
You still need GPSGate to redirect the stream from COM2 (the GPS port) to COM1 (the connector) _________________ Lutz
Posted: Thu Jan 27, 2005 4:23 pm Post subject: |
Thanks for that, all I need now is the pinouts (i have a couple of IPAQ connectors spare from a previous cable and I know the pinouts are different)
Ronnie |
wjb21 Occasional Visitor
Posted: Mon May 09, 2005 7:27 am Post subject: Mio 168 Serial Port |
Did you ever find the pin-out and a serial cable for the Mio 168? - if so, please can you post the details.
Thanks |
