Pocket GPS World :: View topic - POIs on new Navman SmartST V3
Stefan
PostPosted: Wed Jan 26, 2005 8:02 pm    Post subject: POIs on new Navman SmartST V3 Reply with quote
This is my first posting so please forgive me if this is a daft quaestion. I have read the other postings but not worked it out yet. --
I am awaiting delivery of the new ST V3 software to run on my iPaq. I am particularly looking forward to using the large number of POI databases. I appreciate that the speed database can be converted for the Navman V3 software but what about all the other POI databases? Can they be converted or do they only work with TomTom software? Dave Burrows' introductory remarks appear to indicate that I will have to wait for Navman specific POIs to appear.
Stefan
Tim Buxton
PostPosted: Wed Jan 26, 2005 8:18 pm    Post subject: Reply with quote
Don't worry, Stefan. Any POI file in .csv, .ov2. xls etc. can be made to work with SmartST V3 software without too much trouble.
Tim
uffe73
PostPosted: Fri Jan 28, 2005 10:32 am    Post subject: Reply with quote
It would be nice to have an update of POIEdit that supports the Navman csv file format. For small files, it's easy to edit the files manually, but for larger ones it gets a bit tedious...
TomTom GO720T: App ver 8.351(9982/090518), OS:315187, GPS v1.20, Boot 5.5120
TT RDS-TMC: 4V00.013
Maps: Scandinavia v840.2562, Western_Europe v715.1703
Garmin GPSMap 60CSx (SW ver. 3.70)
Tim Buxton
PostPosted: Fri Jan 28, 2005 11:04 am    Post subject: Reply with quote
Are you editing the files to alter coordinates, or other data?
Tim
uffe73
PostPosted: Fri Jan 28, 2005 11:12 am    Post subject: Reply with quote
So far I've only imported POI lists found on the internet to see if it works in the V3 SW. But of course I'll try to create my own files as well further on. The tedious part will probably be to translate a street address into coordinates. I'm guessing that this step has to be performed manually, i.e by looking up the address in SmartST and copying the long/lat information into the POI editor.
/Ulf
Tim Buxton
PostPosted: Fri Jan 28, 2005 11:19 am    Post subject: Reply with quote
What I do is use MS Autoroute 2005. You can create your own POIs, called "Pushpins" or you can import data into autoroute, depending on how accurate the imported data is. You can then save this data as an .axe file and convert it to a .csv file. I don't know how accurate Postcode information is in Sweden. Can you give me a postcode you know to be accurate, and I'll tell you its rough coordinates.
Tim
uffe73
PostPosted: Fri Jan 28, 2005 11:35 am    Post subject: Reply with quote
Thanks for the tip about Autoroute. I might have chance to get my hands on that SW somehow... Wink
It you have time, try entering this addres in MS Autoroute
5 Norra Deltavägen
Göteborg 40222
The coordinate I get from SmartST is:
Latitude: N57°43'43,31"
Longitude: E11°57'20,62"
It would be interesting to see what long/lat information MS Autoroute gives for this address. A big difference between UK and Sweden is the way post codes are being used. In general, a post code area is bigger in Sweden than in the UK (at least if all seven digits are used in UK). Not sure what the story is if only five digits are being used in UK, as is the case in SmartST.
/Ulf
Tim Buxton
PostPosted: Fri Jan 28, 2005 11:49 am    Post subject: Reply with quote
uffe73 wrote:
If you have time, try entering this addres in MS Autoroute
5 Norra Deltavägen
Göteborg 40222
/Ulf
Autoroute returned the address as Göteborg 417, and coordinates of
Latitude: N57°43'39"
Longitude: E11°57'28"
about 50m Southeast of a Garage\Petrol Station.
Tim
uffe73
PostPosted: Fri Jan 28, 2005 12:38 pm    Post subject: Reply with quote
All right, that's close enough. It was the petrol station that was my point of interest. I'm looking to create a POI database with my preferred petrol stations all over the country, built up from an address list.
I will try to get my hands on MS Autoroute and play around a bit with it.
Cheers,
Ulf
Tim Buxton wrote:
5 Norra Deltavägen
Göteborg 40222
/Ulf
Tim Buxton
PostPosted: Fri Jan 28, 2005 12:48 pm    Post subject: Reply with quote
Autoroute is definitely good enough for that, if your address list is accurate. If you can get your address list in a readable format (.xls, .csv, .txt etc.) then you can import it into Autoroute in one hit. It will create all the pushpins and then you can move each one manually as required if you want greater accuracy. I've just done one for BP garages in the UK.
Tim
uffe73
PostPosted: Thu Feb 03, 2005 10:24 pm    Post subject: Reply with quote
Tim,
When I try to load an .axe file into POI Conversion tool I get the following error:
Running ST2GPX V0.5 utility to extract PushPin data
The ST2GPX utility failed to produce the file st2gpx.tmp
Have you seen this error? I'm using version3.09 of the tool.
/Ulf
22.064 (26 Jun 24)
