Pocket GPS World :: View topic - full post code tt mobile
wakaday
PostPosted: Wed Jan 19, 2005 2:03 pm    Post subject: full post code tt mobile Reply with quote
Is it possible to add a full post code search to TT mobile running on SPV_C500? I used to run a search tool from digitools.co.uk on a TT nav 3 which worked well but I'm not sure if it will work on the smart phone.
Any advise appretiated.
lbendlin
PostPosted: Wed Jan 19, 2005 3:16 pm    Post subject: Reply with quote
The tool has not yet been ported to the Smartphone. In the meantime, copy the OV2 files to the map directory and perform the search via custom POIs
Lutz
TomTom/TeleAtlas NAVTEQ
wakaday
PostPosted: Thu Jan 20, 2005 10:01 pm    Post subject: Reply with quote
I've loaded in the Code searchs into the map folder, but unlike other POIs they have not appeared in the POI list?
lbendlin
PostPosted: Thu Jan 20, 2005 10:30 pm    Post subject: Reply with quote
you need to enable each POI group separately.
Lutz
wakaday
PostPosted: Sat Jan 22, 2005 9:50 pm    Post subject: Reply with quote
How do you enable the code seaches as they don't appear in the POI list like the others?
BipolarChucker
PostPosted: Sun Jan 23, 2005 10:24 pm    Post subject: Reply with quote
You need to ensure that the ARCHIVE attribute is set on the ov2 and bmp files while on your phone.
wakaday
PostPosted: Sun Jan 23, 2005 11:25 pm    Post subject: Reply with quote
Checked the properties of the files, they are set to archive type, like other POI.
Is there a max. no. of POI you can list?
Any other ideas?
wakaday
PostPosted: Sat Jan 29, 2005 5:55 pm    Post subject: Reply with quote
I've managed to enable the code searches I want to use. It seems that if you have more than about 80 POIs it will not recognise any further , even if thay are in the GB Map.
22.064 (26 Jun 24)
