JackieD Occasional Visitor
Posted: Sat Jan 22, 2005 10:13 am Post subject: Holux CR100 Car Cradle |
I'm running CoPilot Live 5 Bluetooth on an iPAQ 2210.
This cradle (which has speakers and its own GPS) comes with an install CD but I'm not sure what I should/need to install.
It is asking me to install:
* Winfast Navigator
* Winfast Navigator CE
* GPS USB Driver (which I presume I need if I want to use the cradle's GPS and not my own bluetooth one)
Can anyone offer some guidance?
Jackie |
coham74 Occasional Visitor
Posted: Sat Jan 22, 2005 2:04 pm Post subject: |
Jackie,
I have been running CP5 with a BT receiver on a Dell Axim and have just purchased a CR-100. All that was necessary for installation was to plug the PDA into the cradle, start CoPilot and select the COM1 receiver port (at 4800 baud rate) under the GPS Options/Setup GPS menu. The CR100 is giving excellent reception, good sound and a secure installation - just the job :D As a bonus there is no need to run the BT so two less flashing lights. _________________ Alan
Dell X30/Holux 231/CoPilot 6 Europe
Dell X30/Holux CR-100/CoPilot 5
VDO Dayton MS5500 + TMC (permanent fit)
Garmin eMap
various AVL & telemetry kit (for work) |
Posted: Sat Jan 22, 2005 2:08 pm Post subject: |
Alan
Thanks for the tip. I would have just loaded everything on the CD
Jackie |
Posted: Sat Jan 22, 2005 3:01 pm Post subject: |
Alan
Just out of curiosity, do you leave your cradle in the car or do you take it out when you're not using it? It just seems a bit tempting to thieves, given how much it costs etc! |
Posted: Sat Jan 22, 2005 3:25 pm Post subject: |
Jackie,
Unless it is a secure/trusted parking area the mount is removed from view - as you say, it looks tempting. I find it is best to remove the mount from the windscreen completely, also I think removing the cradle from the arm mounting plate will result in some wear and slop eventually. _________________ Alan
Garmin eMap
Posted: Sat Jan 22, 2005 3:33 pm Post subject: |
Thanks for the tip... |
