Pocket GPS World :: View topic - Arkon powered GPS mount ball joint has failed
jburk
PostPosted: Sat Jan 22, 2005 4:05 am    Post subject: Arkon powered GPS mount ball joint has failed Reply with quote
I just got a new arkon powered GPS mount about a month ago. The GPS and charger have worked great (quick lock, good signal), but the ball joint that connects the flexible arm to the PDA holder has already gone completely loose - it just flops with no resistance whatsoever. Is there any way to tighten it up or do I need to send it back?
roxteddy
PostPosted: Tue Jan 25, 2005 10:50 pm    Post subject: Reply with quote
jburk
i have a different Arkon mount from you but i would imajine the suction plate and ball-joint are the same ?
If they are the same then you need to remove the mounting plate (should be a slide and clip type fit) and you will find a cross-head screw in there that is used to tighten the ball-joint up.
iPAQ 2210 ROM 1.10, TomTom BT 9821X GPS
TT Nav 3.30 (427), GPS V3.03 415/408
Dane-Elec 512MB SD, Arkon CM705 mount
