Pocket GPS World :: View topic - Navman 635
Navman 635
david44
PostPosted: Fri Jan 21, 2005 8:44 am    Post subject: Navman 635 Reply with quote
I have just bought the new navman 635 and are trying to add the camera database to it, i am not good at this,I have down loaded the zip file to my docs, can open it and see all the files, do i then just open the Excel files and delete the 1st two columbs(all the Longitude and Latitude info) and then file them,or do i have to do anything with the other files pictures,etc.
Hope some one can undrstand me.
Many Thanks
Tim Buxton
PostPosted: Fri Jan 21, 2005 11:26 am    Post subject: Reply with quote
Please read the comprehensive instructions which can be found here.
Tim
david44
PostPosted: Fri Jan 21, 2005 12:22 pm    Post subject: Navman Instructions Reply with quote
I have looked at the instructions, do i have to remove both lines of Latitude and longitude, so just the description line is left, as i am not sure as on page 4 it shows them back again.
Sorry i am not good at this kind of thing Sad
Tim Buxton
PostPosted: Fri Jan 21, 2005 12:33 pm    Post subject: Reply with quote
No Exclamation You don't remove the first two columns as that would remove all of the coordinates you're trying to plot. Using Notepad you remove the top line only. (Long, Lat, "Name"). You should still end up with three columns, just the top row of words should be removed.
Tim
david44
PostPosted: Fri Jan 21, 2005 2:43 pm    Post subject: Thanks Reply with quote
thanks very much for the help, what do i do with the other BMP and OV2 files in the zip file.
Many Thanks
Tim Buxton
PostPosted: Fri Jan 21, 2005 3:21 pm    Post subject: Reply with quote
Use them as well. There should be .csv files for Gatso, Specs, Redlight, Mobile, Temp and Continental. You could probably leave out continental unless you're going to mainland Europe. The others cover the different types of cameras.
Tim
PostPosted: Fri Jan 21, 2005 3:30 pm    Post subject: Re: Thanks Reply with quote
Many Thanks
The other files (i.e. not the .csv and .bmp files) are provided for users of other systems and you can ignore them.
david44
PostPosted: Fri Jan 21, 2005 7:56 pm    Post subject: Help please Reply with quote
I have been able to add some of the Gatso files to the 635 and the camera icon and they are working on the map. but it would seem that some of the exel files that i have tranfered onto notepad will not work it says wrong format.
Am I doing some thing wrong, I have been adding one file at a time is this correct, and only the exel files ?
Tim Buxton
PostPosted: Fri Jan 21, 2005 8:14 pm    Post subject: Reply with quote
The database files come in .xls and .csv flavour, which display virtually identical icons. The ones you want to use are .csv ones, which appear to have a lower case 'a' and an arrow in the bottom right hand corner of the icon. You can ignore the .xls files as they carry the same data in a slightly different format. Don't forget that each .csv file you want to import will have to have the top row stripped out using Notepad.
Tim
david44
PostPosted: Fri Jan 21, 2005 8:50 pm    Post subject: Thank you Reply with quote
thank you all for the help, one last question is it necessary to down load all the BMP and OV2 file or can i use thr one BMP like the gatso.bmp for all the different cameras
Tim Buxton
PostPosted: Fri Jan 21, 2005 9:27 pm    Post subject: Reply with quote
You can use the one .bmp if you want to, but most people like different ones. You will have to specify the same icon each time, as the POIEditor will default to the .bmp with the same filename as the .csv file.
Tim
david44
PostPosted: Fri Jan 21, 2005 10:50 pm    Post subject: still no luck with 635 Reply with quote
have loaded gatso files ok, but have tried all day and can not get pocket_uk_mobile
pocket_uk_redlight
pocket_uk_specs
pocket_uk_temp
to load, can tranfer on to notepad and looks the same when loading on to unit but then says No poi,s found in input files.
Please help
david
Tim Buxton
PostPosted: Sat Jan 22, 2005 1:11 am    Post subject: Reply with quote
Have you followed the same procedure as with the gatso.csv file? i.e. open the relevent .csv file using Notepad and strip out the top row? The usual problem when you get the error you're describing is that you have either opened the wrong file (.xls instead of .csv) or you haven't stripped out the top row.
Tim
david44
PostPosted: Sat Jan 22, 2005 10:43 am    Post subject: navman 635 Reply with quote
yes i have done the same as the last two files i tranfered,and only used the files with the small 'a' on, coppied them onto note pad.
david44
PostPosted: Sun Jan 23, 2005 9:48 am    Post subject: still not working Reply with quote
I still can not get the above to work
22.063 (19 Jun 24)
