wakaday Lifetime Member
Posted: Wed Jan 19, 2005 2:03 pm Post subject: full post code tt mobile |
Is it possible to add a full post code search to TT mobile running on SPV_C500? I used to run a search tool from digitools.co.uk on a TT nav 3 which worked well but I'm not sure if it will work on the smart phone.
Any advise appretiated. |
lbendlin Pocket GPS Staff
Posted: Wed Jan 19, 2005 3:16 pm Post subject: |
The tool has not yet been ported to the Smartphone. In the meantime, copy the OV2 files to the map directory and perform the search via custom POIs _________________ Lutz
TomTom/TeleAtlas NAVTEQ |
Posted: Thu Jan 20, 2005 10:01 pm Post subject: |
I've loaded in the Code searchs into the map folder, but unlike other POIs they have not appeared in the POI list? |
Posted: Thu Jan 20, 2005 10:30 pm Post subject: |
you need to enable each POI group separately. _________________ Lutz
Posted: Sat Jan 22, 2005 9:50 pm Post subject: |
How do you enable the code seaches as they don't appear in the POI list like the others? |
BipolarChucker Occasional Visitor
Posted: Sun Jan 23, 2005 10:24 pm Post subject: |
You need to ensure that the ARCHIVE attribute is set on the ov2 and bmp files while on your phone. |
Posted: Sun Jan 23, 2005 11:25 pm Post subject: |
Checked the properties of the files, they are set to archive type, like other POI.
Is there a max. no. of POI you can list?
Any other ideas? |
Posted: Sat Jan 29, 2005 5:55 pm Post subject: |
I've managed to enable the code searches I want to use. It seems that if you have more than about 80 POIs it will not recognise any further , even if thay are in the GB Map. |
