Pocket GPS World :: View topic - Which PDA & Mobile mount?
PaulBoy
PostPosted: Sun Jan 16, 2005 3:43 pm    Post subject: Which PDA & Mobile mount? Reply with quote
Hi - I have recently added GPS / MMap to my serial gadget collecting and was having a look at the GPS Mount Reviews here at GPS World when I spotted TheClip which appears to answer my prayers (?)
I need a mount which mainly will take my mobile phone but when I occasionally use it in the car will also taken my Ipaq (2210)
If I buy TheClip with an extra fitting - stick on pad I believe? - will I be able to swap them around or will this not work (or is there a better solution ?)
Very helpful friendly forum btw ... Paul ;)
Privateer
PostPosted: Sun Jan 16, 2005 6:00 pm    Post subject: Reply with quote
Hi Paul,
I use Brodit mounts in my vehicle. There are three parts, which allow me to swap holders:
Arrow ProClip – this is a fixture to your car’s dashboard
Arrow Move Clip (213005) – this allows you to swap holders that are attached to the ProClip
Arrow Holder – this holds (and can also power) your unit.
However there is nothing stopping you from finding your own best solution by mix-and-match.
Robert.
Garmin Camper 770 LMT-D
Rubberman
PostPosted: Sun Jan 16, 2005 6:17 pm    Post subject: Reply with quote
PaulBoy,
You may also want to check out the Seidio G2500 automotive PDA mount kit. It's a bit pricy; but good value (on sale now at $69.95). It has an enclosed speaker and connections allowing you to simultaneously charge your PDA and receiver through the cigar lighter. The kit also contains a smaller vent mount as well as the goose-neck, suction cup mount.
PaulBoy
PostPosted: Sun Jan 16, 2005 9:16 pm    Post subject: Reply with quote
Rubberman & Privateer ... Thanks for the input I will check those out - do either of them allow you to mount a phone or a PDA in the same mount which it appears the ClipOn allows you to ? That is the most important functionalitiy (is this a word?) of whatever I choose as I mainly would have my phone in it but occasionally would want to mount my Ipaq in it
TIA ... Paul ;)
PostPosted: Sun Jan 16, 2005 10:21 pm    Post subject: Reply with quote
If you use the Brodit system then the 'Move' clip allows you to remove cradles from the vehicle ProClip quickly and simply. You could then attach or remove the Phone/PDA Cradle as necessary.
22.101 (03 Oct 24)
