Pocket GPS World :: View topic - ActiveSync: "Your device is not connected"
RS2000
PostPosted: Sun Jan 16, 2005 2:26 am    Post subject: ActiveSync: "Your device is not connected" Reply with quote
I have active sync 3.7.1 installed on my PC. Which is running windows XP pro. When i connect the phone to the computer, the little green disc has it little spinning action. Then i get "Your device is not connected".
If i click on get connected it goes to the looking for devices & then just shows "Your device is not connected again".
Surely it knows the phone has been connected, as it starts the little green thing spinning when i first connect it?
Any idea's greatly appreciated.
Paul
RS2000
PostPosted: Sun Jan 16, 2005 2:30 am    Post subject: Reply with quote
In device manager, under windows CE USB, the phone is listed
Pocketgps
PostPosted: Sun Jan 16, 2005 2:34 am    Post subject: Reply with quote
What make and model of phone is it ?
Have you looked at the ActiveSync menu on your phone to check that its set correctly.
PocketGps
RS2000
PostPosted: Sun Jan 16, 2005 2:44 am    Post subject: Reply with quote
it's a SVP C500, I had the same prob's with the medion PDA that i used to have. When plug it in. The little green thing would light up and spin for a few seconds & then go out again. I have just checked the settings in active sync.
All buttons are checked?
PostPosted: Sun Jan 16, 2005 2:56 am    Post subject: Reply with quote
Uncheck everything but USB (assuming you connect via USB), and then reboot your PC.
You may also want to delete existing ActiveSync partnerships, and then establish a new one with the phone.
Please try to avoid double postings.
RS2000
PostPosted: Sun Jan 16, 2005 3:19 am    Post subject: Reply with quote
I am connecting via usb, tried unticking all but "connect through usb" Still no difference thou. I've also tried plugging into different usb sockets. No joy. I just get "your device was not detected".
I also get this when i try & connect it onto my laptop as well?
Pocketgps
PostPosted: Sun Jan 16, 2005 7:16 pm    Post subject: Reply with quote
Hello RS2000
The only advice I can give you is to uninstall ActiveSync on your main PC, then reboot, go to
http://www.microsoft.com/downloads/details.aspx?FamilyID=d2645c21-8a85-45a2-8d13-653beb6cdddc&DisplayLang=en
Download new version 3.8, install this new version and try again to see if that will work, I say this because if both your phone and laptop will not work then it must be a problem with ActiveSync on yur main PC.
Regards
PocketGps
RS2000
PostPosted: Sun Jan 16, 2005 10:49 pm    Post subject: Reply with quote
I had 3.8 downloaded from MS at first. uninstalled that ver, as i saw some posts saying that 3.7.1 was a better ver. I had just the same prob's with that one thou.
today i tried disabling windows firewall, rebooting and still the same.
I uninstalled active sync, deleted in device manager, re-installed and re-set up. No joy.
The only thing i can think of, is when click on get connected and the status window opens to say your device was not detected. The com port 2 says unavailable. Could that be the port my USB cable is connected to. As when searching for device it searches com 1 & 3, ir, & usb. But not com 2.
I know it's not the cable, as i connected it straight away on my friends machine this afternoon. He's running the same OS as me?
Paul
Pocketgps
PostPosted: Mon Jan 17, 2005 1:03 am    Post subject: Reply with quote
Hello RS2000
Take it that's the Ford version (RS2000 - nice motor, i had a RS1600 along time ago).
When you re-installed ActiveSync, did you have your phone connected to the UBS lead, because this could cause it not to install correctly, i am just trying to find any problem, cannot understand this any more than you.
Regards
PocketGps
RS2000
PostPosted: Tue Jan 18, 2005 10:54 pm    Post subject: Reply with quote
Thanks very much for the help here people's, I sorted it now. I uninstalled a timed version of McAfee thingy. & with windows firewall turned off it alls runs pukka now.
Thanks very much.
(It is the Ford version. 1988 model, ALL original, immaculate condition. 22000 miles with all MOT's and full ford service history. Costs me £22 a month in gas to keep the garage warm where i store it. Laughing Out Loud...)
Paul...
22.064 (26 Jun 24)
