Pocket GPS World :: View topic - connection
connection
Post new topic   Reply to topic    Pocket GPS World Forum Index -> PDA/Smartphone Discussion
tinytony
PostPosted: Thu Jan 13, 2005 6:52 pm    Post subject: connection Reply with quote
hi all i hope you can help how do i connect medion md95025 to the internet to use the internet explorer ? thanks for any answers
OBH6UK
PostPosted: Thu Jan 13, 2005 7:15 pm    Post subject: Reply with quote
Four way at least, which one do you wish to use?
Activesync
GSM
GPRS
Wi-FI
Pocketgps
PostPosted: Thu Jan 13, 2005 8:35 pm    Post subject: Re: connection Reply with quote
If you are using the Medion docking station then just click ActiveSync - Options - Rules, then in the Pass Through box select The Internet.
Go on line as normal, then you should be able to use Explorer etc on your Pocket PC
Regards
PocketGps
tinytony
PostPosted: Fri Jan 14, 2005 6:38 pm    Post subject: Reply with quote
thanks for repllies
how would i go about doing it wi fi ?
would it be by a card of some sort
OBH6UK
PostPosted: Fri Jan 14, 2005 8:01 pm    Post subject: Reply with quote
Sandisk, SD Wi-Fi card, with or without 256Mb of memory assuming your Medion supports SIDO, my older 406000 does not sure about yours. You would also need a wireless router if you haven't already got one if using at home as opposed to Wi-Fi Hotspots.
http://www.sandisk.com/retail/c-wifi-sd.asp
http://www.sandisk.com/retail/256mb-wifi-sd.asp
tinytony
PostPosted: Mon Jan 17, 2005 7:58 am    Post subject: Reply with quote
thanks forhelp
Post new topic   Reply to topic    Pocket GPS World Forum Index -> PDA/Smartphone Discussion All times are GMT + 1 Hour
22.064 (26 Jun 24)
