Pocket GPS World :: View topic - About to Throw Ipaq Out the Window
marky999
PostPosted: Fri Jan 14, 2005 3:05 pm    Post subject: About to Throw Ipaq Out the Window Reply with quote
Now proud owner of Ipaq 4150 and Fortuna BT ClipOn. Installed TTN3 3.07 and TTN GPS 3.07 but can't get it to fix a position.
The correct lights are on on the ClipOn (It says it has a fix), the BT connection seems to be made but no matter what driver I select and believe you me I've tried them all!! I can't get it to show me any satellite info and get a fix. The only port it will let me use is BT serial on Com 6 so that takes out one of the variables so am I missing something obvious?? I've completely uninstalled everything and tried a previous version of TTN GPS (2.07) as suggested by Lutz when I asked for the best set up in the first place but still no joy.
Help anyone? Before the kit does a swallow dive out the window.
marky999
PostPosted: Fri Jan 14, 2005 3:41 pm    Post subject: Reply with quote
Disregard Above!!!
It's just started working. I suddenly remembered reading that some guy had a similar problem and solved it by moving the ST/XT switch on the ClipOn to XT and then back to ST. I tried it and now it magically works.
All I need to know now is why the voice test doesn't work. I installed the UK voice files off the CD to the default location but they don't seem to work.
Anybody?
Please
22.101 (03 Oct 24)
