Pocket GPS World :: View topic - Tosh e400 / rikaline gps help
TheTillerman
PostPosted: Wed Jan 12, 2005 3:09 pm    Post subject: Tosh e400 / rikaline gps help Reply with quote
I have a tosh e400 running medion navigator and have recently purchased a rikaline gps receiver/charger cable.
I am having problems in getting the PDA to recognise the gps.
Thus far I have tried the driver that is available on Rikalines website (pl2303) but when I try to install I get an error message saying that it is not compatible with my operating system (pocket pc 2003).
Is there a recommended driver for PPC 2003? or any other ideas....
thanks in advance.
DavidW
PostPosted: Wed Jan 12, 2005 3:15 pm    Post subject: Reply with quote
Hello and Welcome
Is that the error that says that the selected software may be for a previous version of the operating system, but allows you to press OK? If so, what happens if you press OK - that error is usually completely benign. Do things work then?
TheTillerman
PostPosted: Wed Jan 12, 2005 3:33 pm    Post subject: Reply with quote
It does seem to work when I press OK but Medion still has "GPS!" in the top right corner - apparently this means that it cannot see the GPSr.
I am also using GPSdash - and I may be having some progress.
If I set it to COM2, 4800 NMEA, I do get something more legible on the data screen... GPGSV, $GPRMC messages and the like - is this a sign of progress....
If so, then I guess I have to figure a way of getting medion to talk to Com2......
DavidW
PostPosted: Wed Jan 12, 2005 3:47 pm    Post subject: Reply with quote
You've got GPS input on COM2 - lines that begin $GPGGA, $GPGSA, $GPRMC etc are what NMEA GPS input looks like.
It sounds like the challenge now is to configure the software.
TheTillerman
PostPosted: Wed Jan 12, 2005 4:13 pm    Post subject: Reply with quote
This is bizarre.
Gps dash shows 5 sats, position etc...
Medion - nothing. Even though I have set up the correct comport (Com2: USBSER) and the baud rate is the same as GPSDash...
any ideas?
lbendlin
PostPosted: Wed Jan 12, 2005 4:21 pm    Post subject: Reply with quote
Please post a few lines of the NMEA data stream. Maybe your receiver is not sending some of the NMEA sequences that the Navigon program needs.
Lutz
TomTom/TeleAtlas NAVTEQ
TheTillerman
PostPosted: Wed Jan 12, 2005 4:48 pm    Post subject: Reply with quote
Here are a few lines garnered from GPS Dash
$GPGGA,004754,5050.705078,N,00105.1170,W,1,08,1.1,203.9,M,48.0,M,,*50
$GPVTG,149.9,T,149.9,M,0019.5,N,0036.0,K*46
$GPGGA,004755,5050.701660,N,00105.1138,W,1,08,1.1,203.9,M,48.0,M,,*56
$GPGGA,004756,5050.701660,N,00105.1138,W,1,08,1.1,203.9,M,48.0,M,,*55
$GPVTG,141.2,T,141.2,M,0019.5,N,0036.0,K*46
$GPGGA,004757,5050.697754,N,00105.1084,W,1,08,1.1,203.9,M,48.0,M,,*5A
$GPGGA,004758,5050.693359,N,00105.1030,W,1,08,1.1,203.9,M,48.0,M,,*57
$GPGGA,004759,5050.693359,N,00105.1030,W,1,08,1.1,203.9,M,48.0,M,,*56
TheTillerman
PostPosted: Wed Jan 12, 2005 4:51 pm    Post subject: Reply with quote
There were also some GPRMC, GPGSV and GPGGA messages too
lbendlin
PostPosted: Wed Jan 12, 2005 5:05 pm    Post subject: Reply with quote
You seem to be missing GSA
Here's the preferred setup
GGA every second
GSA every second
GSV every 5 seconds
RMC every second
Can you try this? (You can set it with Crux_View)
Lutz
TheTillerman
PostPosted: Wed Jan 12, 2005 5:38 pm    Post subject: Reply with quote
I think the logger wasn't working right...
I actually get:
GGA 1 message every sec
GSV 3 messages /sec
RMC 1 message /sec
GSA 1 message /sec
but have now changed these to your suggested settings using the crux utility, and.....
Bah! Still no recognition of the GPSr Sad
lbendlin
PostPosted: Wed Jan 12, 2005 5:53 pm    Post subject: Reply with quote
Are you sure that no other program is running in the background when you try the Medion? Do a soft reset, start the Medion software and try to configure the GPS again.
Lutz
TheTillerman
PostPosted: Wed Jan 12, 2005 5:57 pm    Post subject: Reply with quote
Absolutely nothing else running at all.
Even after a soft reset, no change.....
Bizarre...eh?
lbendlin
PostPosted: Wed Jan 12, 2005 6:08 pm    Post subject: Reply with quote
Indeed.
Can you install Mapopolis and see if that works? (they have downloadable demo maps, too)
Lutz
TheTillerman
PostPosted: Thu Jan 13, 2005 1:05 am    Post subject: Reply with quote
Thanks for the tip.
Will try this over the next day or so and will post results.....
Thanks again.
TheTillerman
PostPosted: Thu Jan 13, 2005 10:11 pm    Post subject: Reply with quote
Okay, Tried mapopolis and it works an absolute treat. :D
I guess my next move is to re-install the medion software.
Failing that I will have to look at another package - any suggestions...??
thanks again for all the help thus far...
22.063 (19 Jun 24)
