Pocket GPS World :: View topic - American Garmin 60cs unit works in Europe??
jlabro
PostPosted: Mon Jan 10, 2005 9:57 pm    Post subject: American Garmin 60cs unit works in Europe?? Reply with quote
Hello, i would like to ask whether the Garmin 60cs unit bought from US , works fine in Europe,meaning , can i load a european map or whatever i want or i should "unlock" the unit or something else ? ?
Can anyone help me ??
Thank you very much
Tim Buxton
PostPosted: Mon Jan 10, 2005 10:10 pm    Post subject: Reply with quote
You will need to buy the European version of CitySelect. Or you could get an European R&R if you can find it, but you won't get automatic routing and it's a couple of years old. It doesn't need unlocking, though.
Tim
jlabro
PostPosted: Mon Jan 10, 2005 10:57 pm    Post subject: Reply with quote
so all i have to do is buy the US unit,and with City select, european version,delete the old map and load the european ?
can it be done with maproute ??
What is the differense ??? Confused
Thanx a lot Smile
jlabro
PostPosted: Mon Jan 10, 2005 11:24 pm    Post subject: Reply with quote
the unit (will buy it from US)will come with the us map in it !
Can you tell me how i will delete the american map and load the european ?
This can be done with CITY SELECT only ?
Skippy
PostPosted: Mon Jan 10, 2005 11:44 pm    Post subject: Reply with quote
The thing to rememer is that many Garmin GPS units come with a rough "basemap" which is accurate to about 500 meters and shows major roads in either the Americas, Europe or Pacific areas. You cannot change this basemap.
If you buy an American model GPS then you will get the Americas basemap with little or no detail of Europe. You can load the maps from City Select Europe to get the accurate, detailed maps of the area you want, but the entire UK is > 130 Meg so you won't fit it all on your GPS.
You can upload small portions of the maps, usually what you would do would be load the maps of your start and destination (say) London and Edinburgh and use the basemap to navigate in the between areas.
The GPS units which larger memory are not such a problem because you can just load the detailed maps for your entire journey...
Also, once you add up the total cost of buying the GPS 60 and City Select, you may be better off stretching your budget a bit and buying Garmin Quest for £350 (European Spec) which comes bundled with City Select, full European maps unlocked and 243 Meg of memory. (beware of US spec Quests only have 115 Meg of memory)
Decisions... Good luck. Confused
Gone fishing!
Skippy
PostPosted: Mon Jan 10, 2005 11:52 pm    Post subject: Reply with quote
Sorry, I was looking at the GPS60 (with 24 Meg RAM) not the GPS 60CS (56 Meg RAM and electronic compass/altimeter) you mention. It's still worth considering the Quest though. Smile
Gone fishing!
jlabro
PostPosted: Mon Jan 10, 2005 11:57 pm    Post subject: Reply with quote
ooook..so i can change the basemap which is good !
It doesn't matter which unit (US or EUROPEAN) i choose , as you said,i can change the base map ! Smile
about the unit.. you put me into thought.. although the memory seems to be enough (with mapsource guide) ,it may cause problem later..
the maps from mapsourceguide and city select are of the same size,aren't they ??
Smile
Thanks again,and sorry,but i am new into this
jlabro
PostPosted: Tue Jan 11, 2005 12:04 am    Post subject: Reply with quote
you wrote :
The thing to rememer is that many Garmin GPS units come with a rough "basemap" which is accurate to about 500 meters and shows major roads in either the Americas, Europe or Pacific areas. You cannot change this basemap. If you buy an American model GPS then you will get the Americas basemap with little or no detail of Europe. You can load the maps from City Select Europe to get the accurate, detailed maps of the area you want, but the entire UK is > 130 Meg so you won't fit it all on your GPS.
You mean that if i get the US version and load the european map
i will have both US and european map on it ?? if i get the european map and already the unit has the european map,i do not need to use the 56MB and load the european map ??
jlabro
PostPosted: Tue Jan 11, 2005 12:17 am    Post subject: Reply with quote
the memory that the basic map uses,is within the 56 MB of total or whatever map is the basemap (US OR EU) there are still 56 mb of memory to do whatever you want ??
Skippy
PostPosted: Tue Jan 11, 2005 12:19 am    Post subject: Reply with quote
Nooo! You can't change the basemap but you can load detailed maps from City Select.
Basemap = major roads for Americas OR Europe OR Pacific. The basemap depends on where you buy the GPS - you can't change it.
City Select Europe = Detailed maps of Europe which take up a lot of space so you have to choose which ones to upload.
The problem is that if you drive from (say) London to Rome then the maps for the complete trip won't all fit in the memory of your GPS so you would load the City Select maps for London and Rome only. In this case, the GPS uses the basemap of major roads where it doesn't have the detailed City Select maps available.
If you have the Americas basemap then there will just be a blank space where the City Select maps are not loaded. Whereas if you have the European basemap version (Garmin call it the "Atlantic Basemap"), it will have a rough map of the major roads to get you to Rome where it will switch to the detailed maps again.
Umm, do you mean Metroguide? Metroguide is NOT routable so the GPS will show you a map of the the roads but will not give you turn by turn directions which makes Metroguide a waste of time. You have to have City Select for routing.
Good luck!
Gone fishing!
jlabro
PostPosted: Tue Jan 11, 2005 12:25 am    Post subject: Reply with quote
Now i got it Smile
thanx a loooooooooooooot
YOU ARE SUUUUUUUUUUUUUUUPER
Skippy
PostPosted: Tue Jan 11, 2005 12:27 am    Post subject: Reply with quote
The 56 Meg is available for uploading maps of your choice.
As a rough guide, 56 Meg would allow you to load detailed maps covering an area roughly bounded by Birmingham in the North all the way to the South coast and from Newbridge/Taunton in the West all the way to the East coast.
Gone fishing!
jlabro
PostPosted: Tue Jan 11, 2005 12:33 am    Post subject: Reply with quote
got it !
thanx again !!
u know a lot !!
Greetings from Greece
22.055 (29 May 24)
