Pocket GPS World :: View topic - Holux 230 and how to configure?
lorenzolamas
PostPosted: Sun Jan 09, 2005 6:20 am    Post subject: Holux 230 and how to configure? Reply with quote
Hi forum,
I'm quite new to this... Anyway, a couple of Q's...
I have Holux 230 and a BT enabled laptop. (Acer Ferrari 3200).
How do I configure my Holux 230? Power Saving mode, SiRF, NMEA, etc. The 230 came with a little app called GPS Viewere, where I can set these parameters (permanent). Are these saved on the chip until I change them, even if 230 turned off or connected to another host program, like TomTom or Autoroute/Streets & Trips?
Also, what baud rate is preferable? In the manual it says 38400, but some apps gives me an error msg especially when requiring NMEA to set to 4800.
Last, I bought an external antenna with the 230, but when using the external antenna I get no signal/lock what so ever. After checking around on the net it seems I have a bought just the antenna cable for an active antenna set... I'm I correct?
Please advice and all the best,
PostPosted: Sun Jan 09, 2005 7:04 am    Post subject: Reply with quote
Bluetooth receivers are auto sensing. So it doesn't really matter what speed you select. Even though 38400 is the most common speed, they work equally well at 4800
Speed and protocol settings are stored on the receiver , but these settings are only preserved until the receiver runs out of battery. If the battery goes down the receiver sets itself back to factory settings
For the time being stick to NMEA (don't try SiRF) and also don't yet play around with Power Saving mode.
The active antenna should normally work. (You are trying this outside, with sky view, right?)
If it doesn't , check the connectors and the cable - those are very fragile and may be damaged. Don't forget, we are talking high radio frequency here - any small physical damage can mean total functional failure.
lorenzolamas
PostPosted: Mon Jan 10, 2005 4:43 am    Post subject: Reply with quote
Hi, thanks for inputs.
Yea, the antenna work very well now. I don't know why it didn't work yesterday... When clear view (car roof) I get generally 9-10 sats, which should be sufficiant to get a good fix, or...?
Anyway, maybe a stupid question but, the antenna is supposed to be on the car roof in exposed to sun/rain/wind/snow? Also, when the external antenna is attached does the main 230E main device have any influence on the receiving conditions?
This is the antenna:
All the best and thanks for help,
PostPosted: Mon Jan 10, 2005 5:23 am    Post subject: Reply with quote
(Interesting - no image is displayed when using Mozilla)
Yes, the external antenna is watertight and can stay outside at all times
When the external antenna is plugged in the receiver's antenna is disabled and doesn't influence reception any more.
lorenzolamas
PostPosted: Mon Jan 10, 2005 6:20 pm    Post subject: Reply with quote
OK, great thanks!
PS. The image shows up fine here using Firefox 1.0. Perhaps you have enabled "Images from originating site only" in your browser preferences? ...just a thought.
PostPosted: Mon Jan 10, 2005 6:47 pm    Post subject: Reply with quote
yes, that was it. Nice to see that security actually works Confused
22.071 (03 Jul 24)
