Pocket GPS World :: View topic - Rikaline 6010 withToshiba e570 and tomtom3
paddyator
PostPosted: Mon Jan 10, 2005 3:26 pm    Post subject: Rikaline 6010 withToshiba e570 and tomtom3 Reply with quote
Hi folks,
I really need your help. I just bought a GPS 6010 to use on my Toshiba e570 with TomTom 3. I cannot get it to work no matter what I do. In the GPS settings under the GPS tab I have selected Rikaline GPS-6010 and Serial Cable on COM1:
When I have it all connected in my car, the light on the receiver flashes but I never get any reception and have yet to find even one satalite!
The serial number of the unit is 60153960
Any ideas where I may be going wrong.
Any help would be very much appreciated.
Darryl
lbendlin
PostPosted: Mon Jan 10, 2005 3:43 pm    Post subject: Reply with quote
serial cable? The Toshiba may not have a serial port (only USB)
Lutz
TomTom/TeleAtlas NAVTEQ
paddyator
PostPosted: Mon Jan 10, 2005 3:48 pm    Post subject: Reply with quote
yes its a serial cable that goes into the same slot that my sync cradle does.
I bought the receiver from PDA Mods and it came with the lead for the PDA. I checked the part number and it is the correct lead.
Any ideas?
lbendlin
PostPosted: Mon Jan 10, 2005 3:52 pm    Post subject: Reply with quote
Is your sync cradle serial or USB? Having the same connector doesn't mean much.
Lutz
paddyator
PostPosted: Mon Jan 10, 2005 3:58 pm    Post subject: Reply with quote
the cradle I use is usb but I did know somebody that had a serial lead to sync.
Hope this helps!?!
lbendlin
PostPosted: Mon Jan 10, 2005 6:40 pm    Post subject: Reply with quote
Can you take the 6010 to that person to try it out? Maybe they used a USB > Serial converter cable.
Lutz
paddyator
PostPosted: Tue Jan 11, 2005 9:27 am    Post subject: Reply with quote
Unfortunately he got rid of his to get an xda a while a go.
I have emailed Rikaline and they told me to disable my IR port and select comm 1 on the tomtom settings. I have selected comm 1 but I dont know how to disable my IR.
Darryl
DavidW
PostPosted: Tue Jan 11, 2005 8:48 pm    Post subject: Reply with quote
The answer you've got sounds like the right answer for an XDA, not a Toshiba. If you want to try it, look in Start Menu, Settings, Connections tab, Beam.
As Lutz says, you need to make sure your Toshiba (and/or your cable) has all the necessary hardware and drivers in place. Quite a few Toshiba Pocket PCs have a USB host port rather than a serial port; for those devices you need to have a USB / serial adapter with the necessary drivers on the Pocket PC.
22.064 (26 Jun 24)
