Pocket GPS World :: View topic - Navman ICN510 postcode issue
wiztaz7
PostPosted: Mon Jan 10, 2005 1:34 pm    Post subject: Navman ICN510 postcode issue Reply with quote
Newbie here. I have found that the ICN510's postcode's are not very accurate. If you enter the full 5 digits, it normally says "No results found"
Is this normal or are there newer maps?
Thanks in advance
Tim Buxton
PostPosted: Mon Jan 10, 2005 1:48 pm    Post subject: Reply with quote
The maps and postcode data shipped with the 510 are the latest available to Navman, or at least from Navman. Can you post an example, bearing in mind that Navman's postcode field accepts upto five characters?
Tim
wiztaz7
PostPosted: Tue Jan 11, 2005 12:22 pm    Post subject: Reply with quote
If you try "E6 5ZJ" or "E12 5PP" they dont work. No match found. If you enter E12 5 then it gives u a large list. Cannot not be specific.
The above are examples I can remember. I tried a postcode in Westminister and it did the same.
Tim Buxton
PostPosted: Tue Jan 11, 2005 7:21 pm    Post subject: Reply with quote
OK, E6 5ZJ will not work, the best you can get is E6 5. You can put in the first part of the postcode, then the first character of the second, hence upto five characters. My parents' postcode is LE15 7XX, and if I put in Le15 7, then the name of their road, it picks it straight away. I don't know exactly what Navman claim, but postcode search depends on knowing the name of the road, too, as far as I can tell.
Tim
wiztaz7
PostPosted: Wed Jan 12, 2005 11:26 am    Post subject: Reply with quote
I just think that post code search should be the easiest as a road only has ONE code so they just have to get the data from the same place the postel service do Rolling Eyes
Tim Buxton
PostPosted: Wed Jan 12, 2005 11:43 am    Post subject: Reply with quote
Actually, many roads have two or even more codes, and it's possible that the data that the Post Office use is copyright; if this is so then that data would have to be licenced, thereby increasing the cost of the product. Most products of this nature only use the upto five character input limitation.
Tim
wiztaz7
PostPosted: Wed Jan 12, 2005 12:06 pm    Post subject: Reply with quote
ok....thanks for the info Smile
Tim Buxton
PostPosted: Wed Jan 12, 2005 12:20 pm    Post subject: Reply with quote
...but here is an offering from the AA which does claim full postcode search. It claims that this feature is unique.
Tim
22.062 (12 Jun 24)
