maggio Occasional Visitor
Posted: Sun Jan 09, 2005 11:39 am Post subject: 3.07 and ipaq 4700 problems |
Hello
for a special application, i need to assign zoom in-outt functions to 2 of the 4 hardware buttons. but i cant get results. the zoom seems to be working only with predefined trackpad functions. i laso de-assigned zoom function to the trackpad but..no result. Anyone can do-know how to do that?
thanks!
massimo |
DavidW Pocket GPS Moderator
Posted: Sun Jan 09, 2005 10:26 pm Post subject: |
Are you saying the zooming works fine with the trackpad but not with other hardware buttons?
I was wondering if the problem was the automatic zooming over-riding what you were trying to do manually. If so, that can be turned off in File -> Properties, Advanced tab.
Another potential problem is that the hx4700 has built in software to turn long presses into 'other' buttons - for example, a long push on button 1 is actually button 6. Is this your problem?
David |
Posted: Mon Jan 10, 2005 1:08 pm Post subject: |
David, thanks for reply.
Yes, the zoom function work with onscreen +- and with trackpad, not with assigned hw button. I never understand what auto zoom 2d, 3d was; btw i deselcted it but still the same result.
How can i learn more on "other" buttons? 1 to 6 etc? any of hardware button may have "other function assigned?
massimo |
Posted: Tue Jan 11, 2005 6:03 pm Post subject: |
The auto zoom is Navigator changing the zoom factor of the map according to what it feels your needs are. It works very well, especially in 3D view - as you slow down for a roundabout, the map zooms in.
The button pressing stuff - on the hx4700, a long press on button 1 is button 6, a long press on button 2 is button 7, a long press on button 3 is button 8, and a long press on button 4 is button 9. Most software, including TomTom Navigator 3, doesn't understand buttons 6 to 9, which means that long button presses can't be interpreted by application software.
Does a short push on a hardware button zoom one step?
I'm still not sure whether this is an hx4700 specific feature, a WM2003SE iPAQ specific feature or a built in WM2003SE feature.
David |
