Pocket GPS World :: View topic - Data Transfer. Help please
stanshawe
PostPosted: Sun Jan 09, 2005 6:34 pm    Post subject: Data Transfer. Help please Reply with quote
Hi, could anyone tell me please how I transfer all my data (maps, POIs etc) from my present iCN510 memory card to a new and larger card that I have just purchased. I do have a card reader but I don't seem to be having much luck, any info appreciated.
Rich
Tim Buxton
PostPosted: Sun Jan 09, 2005 7:39 pm    Post subject: Reply with quote
Do you have Custom PIs? If not, you mght be able to just put the new card into your iCN and use Navman Desktop to transfer the maps, etc. to your iCN.
Tim
stanshawe
PostPosted: Sun Jan 09, 2005 7:44 pm    Post subject: Reply with quote
Unfortunately yes I do, in fact loads of them maybe this is the problem. Is there any other way? I have tried copying from the old card to a file on the PC (via the reader) which was OK but when I try to put them back the PC locks up saying unable to read to Drive x (the reader).
Rich
Tim Buxton
PostPosted: Sun Jan 09, 2005 8:08 pm    Post subject: Reply with quote
How are Custom POIs stored on the iCN? Could you transfer the maps in the usual way and then use File Explorer to copy the Directory holding your Custom POIs directly to the SD card when it is in the iCNs slot?
Tim
stanshawe
PostPosted: Sun Jan 09, 2005 8:53 pm    Post subject: Reply with quote
OK Tim, I will give that a go. I think I was probably trying to cut corners by just copying from one card to the other, what I will do is now as you say copy the maps from the CD that came with the unit as if starting from new and then sort out, again as you suggest, getting the POIs over after. The POIs incidentally are located in the 'my POI' section on the card.
Thanks again
Rich
stanshawe
PostPosted: Sun Jan 09, 2005 10:36 pm    Post subject: Reply with quote
All sorted now. Thanks again
Rich
22.063 (19 Jun 24)
