vishalsachar Occasional Visitor
Posted: Sat Dec 04, 2004 5:24 pm Post subject: Port Error with Rikaline GPS-6010/ XDA II |
Hi there,
I have an XDA II, TTN3 and the Rikaline 6010. In the past this set up has worked wondefully without any problems.
However i have recently had to completely reinstall everything after having not used any of it for a few months. Here are the frustrating problems i have, and really really hope someone can help me make use of the expensive equipment i have bought!
When going into TomTom GPS settings, i select my Rikaline in the top box, and choose serial COM1 in the second box.
This brings up an error: Cannot open COM1: Port does not exist.
So i then tried WinFast Navigator, to check if maybe the port was wrong. None of the ports seem to work. Furthermore, whenever i click Port Settings, i get multiple errors saying "Cannot find value". IF i try to select COM1, it brings up another error such as "Cannot open COM1".
Now at first i thought maybe the the GPS receiver was a problem. But it actually does blink as if it was receiving signals.
I hope someone can share a few ideas.
The only problem seems to be the port problem. Is there any way to find out exactly what port i should be using? (i use wired gps which connects to my PDA in the activeSync port).
Thanks to anyone who can help |
DavidW Pocket GPS Moderator
Posted: Sat Dec 04, 2004 6:03 pm Post subject: |
You need to turn off IR beams on the XDA - though I can't remember exactly how that's done.
David |
Posted: Sat Dec 04, 2004 9:25 pm Post subject: |
If that is the simple solution then i thank you many times!
Now all i need is to find out how to turn off IR beams... any ideas, or know where i should be able to find out?
Thanks! |
Posted: Sun Dec 05, 2004 12:37 pm Post subject: |
I don't have an XDA to try it, but try Start Menu, Settings, Connections tab, Beam - and see what you can switch off there.
David |
Cwill Occasional Visitor
Posted: Sat Jan 08, 2005 6:17 pm Post subject: rikaline connecting problem |
I have same problem with viewsonic v37 anyone help pease! |
jasefern Occasional Visitor
Posted: Tue Jan 11, 2005 12:26 pm Post subject: port problems XDAII |
I had the same problem and thank you very much the answer is to turn off the beam under settings connections
again thank you |
rlmaskey Occasional Visitor
Posted: Wed Apr 20, 2005 1:11 am Post subject: |
hi,
I have pdaIIi and recently got tomtom wired gps. I was having the same message.
But, I have turned off the ''FReceive all income beam'' in settings and connection tab. Now the port is enabled for gps
Thanks |
