Pocket GPS World :: View topic - Navman 510i - Persistant error loading POIs' - any advice?
Ghazi
PostPosted: Wed Jan 05, 2005 11:57 am    Post subject: Navman 510i - Persistant error loading POIs' - any advice? Reply with quote
Every time I try to load the POI CSV I get all the way to "transfer to device" in SmartST but then get the error message "No POI's found in input file" - What am i doing wrong? I followed all the instructions verbatum.
Help please? anyone?
Ghaz
icsys
PostPosted: Wed Jan 05, 2005 2:20 pm    Post subject: Reply with quote
If you followed the instructions 'verbatim' there should not be a problem.
Ensure you use NOTEPAD to edit out the top line of the .csv file and not Excel.
Ian.
Navman iCN 635
TomTom GO
Anquet OS mapping
Ghazi
PostPosted: Fri Jan 07, 2005 10:38 am    Post subject: Reply with quote
It still does not work. i am using wordpad to edit the file. Just before clicking the "transfer to device" button / menu item i compared the image of my POI Editor to the one supplied with the instructions - it loos exactly the same.
After selecting "save to device" the POI editor then chuggs along or a while before spitting out "No POIs in Input File". it does this every time.
Anyone else encounter this?
Ghaz.
Tim Buxton
PostPosted: Fri Jan 07, 2005 3:52 pm    Post subject: Reply with quote
Can you email me an example of what you're trying to upload, please?
Tim
Ghazi
PostPosted: Fri Jan 07, 2005 8:28 pm    Post subject: Reply with quote
OK I sent it - thanks for your help
Ghaz
icsys
PostPosted: Fri Jan 07, 2005 9:52 pm    Post subject: Reply with quote
Once Tim has viewed your file he will be able to shed light on where things are going wrong.
Life would be so much better if Navman-ready files were made available in the zip file download .
Ian.
Navman iCN 635
TomTom GO
Anquet OS mapping
PostPosted: Sat Jan 08, 2005 2:24 pm    Post subject: Reply with quote
Wordpad IS NOT NOTEPAD!
Wordpad can sometimes corrupt the file and save in a different format, hence why the instructions do stipulate using notepad.
This may or may not be causing your problem, but hopefully Tim should be able to confirm shortly.
Ghazi
PostPosted: Sat Jan 08, 2005 2:34 pm    Post subject: Reply with quote
You are right but since Notepad is one of the most poular targets for trojans and hackers i don't have it on my system.
A text format file is a text format file - so I am not sure that using Wordpad is causing a problem. I have heard from others with exactly the same issue on the ICN 510 so i beleive this is a problem with the unit.
It is moot for the time being as my cat knocked the 510 off my desk while it was plugged into the USB port and it ripped the femail receptical from the soldered foundation. I am beginning to think the 510 is crap, but there you go. Now i have to find my soldering iron....
Ghaz
PostPosted: Sat Jan 08, 2005 2:51 pm    Post subject: Reply with quote
Actually the most targetted operating system is Windows so are you going to remove that also ? WordPad has more vulnerabilities than what Notepad has, so I would be even more warey of using Wordpad. Providing you are protecting your computer properly then there should be no reason why you can't use notepad, or another plain text editor.
Well I can categorically tell you it's not an issue with the 510 because I have one here running the latest database version of our cameras and it works extremely well.
Ghazi
PostPosted: Sat Jan 08, 2005 8:27 pm    Post subject: Reply with quote
Maybe just a few 510's then? because the instructions are moronically simple I am sure it is not operator error. I can categorically say that the error occurs every time that I try and load the POI file - or any of the POI files. And as I have said - others have had the same error. There seems to be a workaround by transferring the POI files directly to the unit using the 510 directory access in "My Computer" - I will try that... once I have found that damn low-voltage soldering iron...
Thanks for all your help. Please don't respond by insiting that nothing is wrong though. If you do have any information on this error i would be greatful for your help.
Ghaz.
Notepad was removed autoatically by my security software. That's all I know.
Tim Buxton
PostPosted: Sat Jan 08, 2005 8:44 pm    Post subject: Reply with quote
Did you have any joy with the file I sent you? Your file went straight into my PPC.
Tim
PostPosted: Sun Jan 09, 2005 9:32 pm    Post subject: Reply with quote
Correct, others have had a problem, but all of the problems people have experienced so far is because they're either not using NOTEPAD or a virgin text editor or they aren't removing the header line out of the file. Once done, this usually resolves the problem.
PostPosted: Sun Jan 09, 2005 10:52 pm    Post subject: Reply with quote
Ghaz,
I have just re-loaded the GATSO, SPECS and MOBILE to the iCN510 I have here and they've all gone on without fail following the instructions page. That's using NOTEPAD and editing out the first line and re-saving the CSV file as pure text/ascii then opening up the desktop software, opening POI Editor and importing and saving them to the iCN510.
What I would be careful of, if you're getting to the point where you are importing, the graphic will automatically default to the file you are importing CSV and this might be where you are seeing a problem.
Ghazi
PostPosted: Sat Jan 15, 2005 10:57 am    Post subject: Reply with quote
Guys,
Thank you so much for your help!
I have just sucessfully re-soldered the surfacemount USB connector onto the PCB of the 510.
If any of you have cats that are likley to knock the 510 off the desk while it is plugged in to the USB cable (as i do) - then you should know that (on my unit at least) the soldering for the USB connector is seriouslly sub-standard. The connector ripped off the PCB with almost no effort. and on inspection the 4-primary solder points were very poorly soldered - Those Chinese sweat-shops just don't seem to care anymore....
The 5 solder points for the data connection are fiddly - so if anyone experiences a similar problem I have pictures and can send instructions for self repair of the 510 SM USB on the PCB.
Ok - now that I can talk to the 510 again I have taken your advice and ditched wordpad for a proper programmers text editor and the file now transfers without any problem. Cheers and thanks and beers all round!
Ghaz.
jnmann
PostPosted: Fri Feb 04, 2005 9:36 pm    Post subject: No POI's Reply with quote
Did you get then problem transferring the POI's sussed yet? I'm just having first attempts and getting same message, checked everything set as per instructions but still no go. Can you let me know?
Many thanks,
Justin
22.062 (12 Jun 24)
