nicke20 Occasional Visitor
Posted: Sun Jan 23, 2005 10:54 am Post subject: |
Thanks wilko for the link
great piece of software, and nice to be able to swith the auto connect on and off with a screen tap. i didnt fancy a reg tweek using an editor after the comments of the ipaq locking on to a closer bt device
cheers
Nick |
kwr Occasional Visitor
Posted: Mon Feb 21, 2005 5:17 am Post subject: |
help please!!!
i downloaded bluetooth tweaker 1.4 for ipaq 2210, i set automatic(background) and and chooce ipaq 2210 but when i hit apply, i got an error said, widcomm registry key not found!
what happend? i have ipaq 2210 with rom version 1.10, do i have to use this bluetooth tweaker in order to make gps bluetooth work?
your help greatly appreciated, thank you very much. |
selwonk Occasional Visitor
Posted: Mon Feb 21, 2005 5:18 pm Post subject: |
kwr wrote: | help please!!!
your help greatly appreciated, thank you very much. | I've got exactly the same problem on my iPAQ 1940. However, I've used this thread before to fix this particular problem. My iPAQ battery died and the backup/restore in ActiveSynce failed. I've just reloaded the TomTom software and try to fix the registry by hand. The Autoconnect entry is simply not in the registry? I've download the latest Bluetooth driver from the HP website but to no avail
Also weird is that when I exit TomTom the Bluetooth light is flashing but the Bluetooth manager thinks it is turned off? _________________ MK
Mike Knowles |
Posted: Wed Mar 02, 2005 12:31 pm Post subject: |
Just a quick update to this one. I've been unable to resolve the missing Widcomm registry entries. I've even tried installing the 1.00 ROM for the iPaq 1940 but this has not helped
MK |
Sean16 Occasional Visitor
Posted: Wed Mar 02, 2005 8:12 pm Post subject: |
I had the same problem with my 1940, to get around this I set the bt reg tweak to 2210 and for some reason it works :D |
Posted: Thu Mar 03, 2005 10:27 am Post subject: |
Unfortunately it does not work on mine... |
Fucawi Occasional Visitor
Joined: 02/05/2003 13:22:34 Posts: 32 Location: United Kingdom
Posted: Thu Apr 07, 2005 4:33 pm Post subject: |
lbendlin wrote: | Here's something you should try (credits to pocketnavigation.de). You need a registry editor for this.
HKLM\SOFTWARE\Widcomm\BtConfig\Autoconnect\000x
(000x is 0008 for com8 )
add an entry (DWORD)
BtBrowserEnabled=0
this should stop the BT browser from popping up, and the last connected device will be reconnected |
Lutz
I am using Resco Registry and followed the HKEY path you suggested, but once in 0008, I lost where I am supposed to add the DWORD entry. If I make this registry change then will it cause problems with the partnering with the BT phone that i use for TTN Traffic and email/internet etc.
Please could you help with this.
Regards _________________ Where the Fucawi?? |
lbendlin Pocket GPS Staff
Posted: Thu Apr 07, 2005 8:40 pm Post subject: |
Once you have navigated to the 0008 area you simply say File > New > Dword value, name it BtBrowserEnabled and give it the value 0.
It will not interfere with other BT services, it's purely for the outgoing serial port service _________________ Lutz
TomTom/TeleAtlas NAVTEQ |
Posted: Fri Apr 08, 2005 10:10 am Post subject: |
Thank you Lutz, it has worked a treat. No more irritating BT searches.. :D _________________ Where the Fucawi?? |
mcgrelio Occasional Visitor
Posted: Wed May 18, 2005 3:38 pm Post subject: |
Ok, i've done the registry editing and now TT autoconnect. It's great.
However the really great thing would be to have TT autoactivate BT when started.
Someone did the same question and it is still unanswered
It would be great what the BT manual activation do and then putting it into a sort of .bat file wich execute this script and then launch TT.
There's is a small utility called minibt (shareware http://www.pocketgear.com/software_detail.asp?id=16666) but it hangs on my HP4150. |
Posted: Wed May 18, 2005 4:16 pm Post subject: |
TTN5 does exactly that (switching BT on if you haven't done it before), and guess what - I don't like it. Because when BT was already switched on before you started TTN5 it will be switched off when you exit TTN5. 8O
My PDA is controlled by ME, not by TomTom! ![Evil or Very Mad](modules/Forums/images/smiles/icon_evil.gif) _________________ Lutz
Posted: Thu May 19, 2005 1:27 pm Post subject: |
lbendlin wrote: | TTN5 does exactly that (switching BT on if you haven't done it before), and guess what - I don't like it. Because when BT was already switched on before you started TTN5 it will be switched off when you exit TTN5. 8O
My PDA is controlled by ME, not by TomTom! ![Evil or Very Mad](modules/Forums/images/smiles/icon_evil.gif) |
Wow! So i have to buy TomTom5 to have automatic B switching
TT5 switching automatically the BT is fantastic because it reduces user interaction and does what the user should.
However you're right if you want to keep the control of your ppc.
TT5 should simply check if BT is activated or not: if it is, it should not close the BT connection after TT5 is colsed.
This would be a good behaviour, isn't it? |
Posted: Thu May 19, 2005 1:29 pm Post subject: |
I've checked TT site and seen "Avaiable soon" under TT5 Navigator (for PocketPC).
Is it already avaiable? |
Quantum Frequent Visitor
![](modules/Forums/images/avatars/76041576644e0c2c07d95a.png)
Joined: 16/02/2003 03:21:58 Posts: 285 Location: Seattle, Ecotopia
Posted: Tue Jun 07, 2005 2:02 pm Post subject: |
lbendlin wrote: | Because when BT was already switched on before you started TTN5 it will be switched off when you exit TTN5. 8O |
Man, what a basic error. |
