Pocket GPS World :: View topic - External antena and fibre glass
Cloonsey
PostPosted: Thu Jan 06, 2005 1:49 am    Post subject: External antena and fibre glass Reply with quote
Does fibre glass affect the gps signal?
My van roof is fibre glass and if possible i want to put the antena on the inside of the roof.
PostPosted: Thu Jan 06, 2005 5:23 am    Post subject: Reply with quote
Fibre glass should have next to no influence on the GPS signal. Putting the antenna on the inside should work just fine.
Eldar
PostPosted: Thu Jan 06, 2005 12:14 pm    Post subject: Reply with quote
Fiberglass might affect the cental frequency of a patch antenna if it is sufficicently close (up to 2cm) to the antenna.
Podie
PostPosted: Thu Jan 06, 2005 4:13 pm    Post subject: Reply with quote
Absolutely no problems at all... mine lives in a TVR (which are not good for electrical interference generally Rolling Eyes )... had no problems with the standard unit... so not even going to bother with the external antenna..
DavidW
PostPosted: Thu Jan 06, 2005 5:06 pm    Post subject: Reply with quote
You may find it harder to mount the antenna - magnetic bases don't stick to fibreglass!
Meanwhile, many external antennas will be set up to work ideally over metal (acting as a ground plane) - so it may be slightly off tune if not over metal, and slightly less efficient as a result. You can only try it, though, and I'd be surprised if it was that affected by the fibreglass.
Cloonsey
PostPosted: Thu Jan 06, 2005 5:52 pm    Post subject: Reply with quote
Cheers guys,my external antena should arrive tomorrow.
I'll have to experiment abit and report back.
Lotus_Esprit_Turbo
PostPosted: Fri Jan 07, 2005 8:21 pm    Post subject: Reply with quote
Mines fine (fibreglass car as well) :D
I even tried it attached to the underside of my sunroof (that has a carbon fibre panel instead of the glass) and it worked fine through that too.
