mimran74 Occasional Visitor
Posted: Fri Dec 17, 2004 12:34 am Post subject: how to pair leadtek 9537 with ipaq 4150.please help |
i am using leadtek 9537 blue tooth gps receiver and ipaq 4150 ( blue tooth), with tomtom 3 maps.i have been using it for a while.now some how pairing is lost so my dda dont detect it.can someone tell how to configure it with tomtom in simple way.thank u in anticipation. |
DavidW Pocket GPS Moderator
Posted: Fri Dec 17, 2004 3:05 pm Post subject: |
I don't know precisely how the Leadtek deals with pairing, but you may succeed in pairing again if you delete the Bluetooth pairing on your iPAQ via the Bluetooth Manager.
If you turn on Bluetooth, go into the Bluetooth Manager, tap on Tools, Paired Devices, the entry relating to your GPS and tap Remove, then OK and exit the Bluetooth Manager, what happens then if you try to start up your TomTom software?
David |
khizerharoon Occasional Visitor
Posted: Thu Jan 06, 2005 10:56 am Post subject: Pairing BT GPS and other BT Devices |
if u need to pair just detect the Leadtek BT GPS and enter pass code 0000 four consecutive zero's and ur devices would pair.
Regards
Khiz |
mpluga Occasional Visitor
Posted: Wed Feb 09, 2005 7:49 am Post subject: Leadtek bluetooth |
Hi there, I do not know if you have solved your problem as yet, but here it oges try it out.
1/ turn your Leadteak bluetooth on. (Blue light should flash).
2/Turn your Ipaq's Bluetooth on. ( Do not pair it). "there is nothing to pair"
3/Open your GPS Software. & Go to GPS Settings.
4/ Select Comport: 8 57600 NMEA
5/Click on Find GPS..(Not familiar with TOMTOM.)
6/ You should be able to find it with this settings.
But remember you do not need to pair it, as you are not sharing any file with the device, only TX-RX Data.
I hope you have solved the problem....
God Bless |
