Pocket GPS World :: View topic - think i have broke it any help apprieciated
sue
PostPosted: Sun Jan 02, 2005 10:47 pm    Post subject: think i have broke it any help apprieciated Reply with quote
today i have used my navman 510 the battery was getting low and a message came up to connect to power immediately,then before i could connect to power message came up as follows
Application error
Code\Navigator\Gui\Unstable\apps\guiex,c
LINE 763 TEST modal0!=NULL
error during GUI modal call,window not found
if anyone can help it would be appreicated but i am very thick and not good with this type of thing so if you can put it in laymans terms i might be able to do it
please if you can help email me susan.paling@ntlworld.com
thanks.
DavidW
PostPosted: Mon Jan 03, 2005 6:14 pm    Post subject: Reply with quote
I very much doubt that you've broken it!
I don't use an iCN - but is there any kind of reset button? If you're not sure, look at the manual or other documentation. If you find a reset button I'd start out by pressing that to see if it will restart properly.
Hopefully a Navman user will come along to give you a hand soon.
LT4play
PostPosted: Mon Jan 03, 2005 8:06 pm    Post subject: Reply with quote
I have never done this, but from the iCN510 user manual:
Reset iCN
Normally you do not need to reset your iCN, however should your iCN not turn on or not respond, you can reset it to solve the problem.
To reset your iCN, either:
a. Press and hold the Home button. The message Reset Device? will display. Tap Yes.
b. Use the stylus to press the Reset button on the top of the iCN.
22.063 (19 Jun 24)
