Pocket GPS World :: View topic - geko 201 ans Acer N30 PDa
fev1954
PostPosted: Thu Dec 30, 2004 1:25 pm    Post subject: geko 201 ans Acer N30 PDa Reply with quote
hi - i have a geko 201 which i use when walking and sometimes hook up to my laptop for use with autoroute 2005 and it all works fine - but the laptop was bit bulky so i have treated myself to an Acer N30 PDA - and after using the same set up on the 201 and setting the PDA to com port 1, i'm having a bit of a problem in that the PDA is not receiving any data from the Geko 201.
The PDA takes serial connection and is showing com port 1 and the 201 is set for NMEA - software is Pocket Streets from autoroute 2005 - though i'm hoping to move over to tom tom 3 software shortly.
Any ideas as to what i'm doing wrong
lbendlin
PostPosted: Thu Dec 30, 2004 1:26 pm    Post subject: Reply with quote
The Baud rate is set to 4800, right? And the Geko is sending NMEA data?
Lutz
TomTom/TeleAtlas NAVTEQ
fev1954
PostPosted: Thu Dec 30, 2004 1:29 pm    Post subject: Reply with quote
Geko is set for NMEA and 4800 baud rate - what I can check is the baud rate of the N30 - I have sent a note to Acer asking them for infoormation on this
lbendlin
PostPosted: Thu Dec 30, 2004 1:37 pm    Post subject: Reply with quote
The Acer will accept whatever you set in your program (as long as it is betwee 1200 and 115000 (or so)
Any other software blocking the COM port? Keyboard driver? Infrared beam?
Lutz
Pc-Mobile
PostPosted: Thu Dec 30, 2004 1:50 pm    Post subject: Reply with quote
Are you sure the cables are OK?
May be the problem is with the software.
Try com 0, if there is one. Tom Tom definitely use UART 0.
Pc-Mobile
http://pc-mobile.net/gps.htm
fev1954
PostPosted: Thu Dec 30, 2004 1:54 pm    Post subject: Reply with quote
checked the PDA and disabled the infrared port but still no data - one point to mention - i'm using an Acer serial cable which has the special Acer connection on one end and a femal serial on the other but the 201 cable also has a femal serial cable connector - I simply connected them using a serial male to male cable (straigh through no crossover) - i dont think this is the problem but any ideas
Pc-Mobile
PostPosted: Thu Dec 30, 2004 2:05 pm    Post subject: Reply with quote
You need a null modem adapter between the 2 serial cables.
A mere gender changer will not do.
Pc-Mobile
fev1954
PostPosted: Thu Dec 30, 2004 2:21 pm    Post subject: Reply with quote
best laid plans and all that and all you need is a plonker at this end - I have just ordered a null modem adaptor (male to male) should have it in the morning.
will get bakc to let you know how things go
thanks for the speedy help - hope you all have a good new year
fev
Pc-Mobile
PostPosted: Thu Dec 30, 2004 2:29 pm    Post subject: Reply with quote
While you are waiting for that, there is one simple, temporary solution you can make it work.
Get 3 suitable wires and bridge the serial cables (insert them into cable holes) this way:
2>3
3>2
5>5
It should work.
Pc-Mobile
fev1954
PostPosted: Thu Dec 30, 2004 3:27 pm    Post subject: Reply with quote
this is where i look really daft but which is pin 2 etc - as I look at the end of the femal connector is the top row with 5 holes in it numbered 1 to 5
Pc-Mobile
PostPosted: Thu Dec 30, 2004 3:43 pm    Post subject: Reply with quote
pin 2 is the one next to 1 !
And 3 is next to 2 (in the middle of 5)
And you know which is 5.
Pc-Mobile
fev1954
PostPosted: Thu Dec 30, 2004 5:04 pm    Post subject: Reply with quote
Embarassed OK the laugh is on me - so my last post was no the best constructed - all i was trying to find out was which way the numbering went (left to right0 - but thanks for the info and i've also found number four - they say you learn something new everyday - tomorow i'm going for number six - i know it risky given my state of mind but i'm going fo it. :D
fev1954
PostPosted: Tue Jan 04, 2005 2:43 pm    Post subject: Reply with quote
just a quick update and a thank you to all who helped - null modem adaptor arrived and everything is working fine - THANKS FOR ALL THE HELP
CHEERS
FEV
22.101 (03 Oct 24)
