Pocket GPS World :: View topic - Toshiba e335 com1 problem
Littlened
PostPosted: Tue Dec 28, 2004 11:13 pm    Post subject: Toshiba e335 com1 problem Reply with quote
Hi All,
I've recently purchased a GPS receiver for use with my Toshiba E335 pocket pc. I've installed the driver which came with the receiver, but alot of the time I cant get the PDA to pickup the receiver.
I've installed winfast navigator which says it cant connect to com1. If I remove the drivers and re-install then sometimes I can get the GPS to work ok. other times I cant, and have to uninstall the driver again.
I believe the the driver I'm using is proliant PL-203 or similiar.
Can anyone help as 9 times out of 10 I cant get gps working
Littlened
PostPosted: Tue Dec 28, 2004 11:27 pm    Post subject: Reply with quote
I have read that toshibas use port 9, but according to my pda com 9 is the ir port.
Can someone confirm if I should be using com1 or the serial port?
Pc-Mobile
PostPosted: Wed Dec 29, 2004 2:52 am    Post subject: Reply with quote
You cannot uninstall the driver without using a registry editor.
So the original driver is there all the time.
It should be com 1 or 2.
But the driver should not be the problem. You should look somewhere else for the problem particularly the GPS.
Pc-Mobile
http://pc-mobile.net/gps.htm
Littlened
PostPosted: Wed Dec 29, 2004 8:29 am    Post subject: Reply with quote
Yeh I relised I had to remove the registry entries then reset the pda so that I could uninstall the drivers.
Littlened
PostPosted: Wed Dec 29, 2004 8:32 am    Post subject: Reply with quote
I believe its a problem with the driver myself, because someones after I've installed the driver and run 'test' (which is supposed to tell me which port to use) it says ' Device not found. The GPS doesnt need to be plugged in for it to tell me what port to use
Pc-Mobile
PostPosted: Wed Dec 29, 2004 9:13 am    Post subject: Reply with quote
Did you use the driver supplied with the GPS?
If you did then there should be no problem with the driver.
Pc-Mobile
22.101 (03 Oct 24)
