Pocket GPS World :: View topic - using bluetooth tomtom gps on laptop via fugawi mapping soft
tonyg
PostPosted: Sun Dec 26, 2004 11:47 pm    Post subject: using bluetooth tomtom gps on laptop via fugawi mapping soft Reply with quote
Hi all, merry christmas,
I have a problem using bluetooth tomtom gps on laptop via fugawi mapping softare.
Has anyone done this? is it possible?
I have tried to get the bluetooth tomtom gps to work on the laptop with fugawi, every time i try to configure fugawi to use the gps it comes back with a error message "port \.\\com13 is busy" i have checked settings in device manager and set the appropiate settings in fugawi.
Any ideas, please help
Tony
lbendlin
PostPosted: Mon Dec 27, 2004 4:16 pm    Post subject: Reply with quote
Before you try Fugawi use a test tool like VisualGPS to verify the function of the receiver and the connection.
Also, COM13 is a tad high. Try to cleanup your PC a bit and remove unneded BT services so you can get the outgoing COM port below COM10. If necesary, completely remove and re-install the BT stack.
Lutz
TomTom/TeleAtlas NAVTEQ
tonyg
PostPosted: Mon Dec 27, 2004 10:46 pm    Post subject: Reply with quote
Thank you for your reply,
I am now using com6 and have installed visual gps, but still get the same error message or a variation of it, "access denied com port in use" the only service using com 6 is tomtom gps bluetooth the device i want to connect to. if i select within bluetooth settings "tell me about bluetooth wanting to connect" it asks me for a pass key, via a wizard if i cancel, as tomtom does not use a passkey "i think?", it freezes up and after a minute or so gives the same message above.
lbendlin
PostPosted: Tue Dec 28, 2004 12:04 am    Post subject: Reply with quote
Please be aware that it's not the TomTom GPS using the service of COM6, but rather the other way round - your local (outgoing) port COM 6 is using the serial port profile service of the BT GPS.
Are you successful in browsing for BT devices and discovering the services that the TomTom has to offer?
Lutz
tonyg
PostPosted: Tue Dec 28, 2004 12:42 am    Post subject: Reply with quote
when asked for a passkey by the bluetooth connection wizard i entered 0000 (supplied by your self in the tom tom forum) and visual gps is working now and "amazingly" so is fugawi:) HORRAY!!
Thanks again for your time, and advise
