Pocket GPS World :: View topic - Trine II DataLogger - ? SW to plot ? newbe
pwwuk
PostPosted: Mon Dec 27, 2004 10:32 am    Post subject: Trine II DataLogger - ? SW to plot ? newbe Reply with quote
I am new to this, do please help
Trine II links fine to PDA & PC. Can transer files from GPS to PC & PDA no worries via BT.
Howver the ascii file has only a lat long time, the bin file the docs suggest has altitute, speed etc.
I want to be able to plot from the datalogger (car jouneys, flights in my light AC etc) .. But have no idea what SW will read / plot the bin files.
Sorry, but I need advice ..
Peter
lbendlin
PostPosted: Mon Dec 27, 2004 5:20 pm    Post subject: Reply with quote
for starters, stick with the ascii file. Use Microsoft MapPoint or similiar to plot your tracks.
if you use the binary format you are wasting precious memory on the Trine . you only need this for geo surveying.
Lutz
TomTom/TeleAtlas NAVTEQ
pwwuk
PostPosted: Mon Dec 27, 2004 8:19 pm    Post subject: Reply with quote
Thanks for the advice ..
The ASCII File does not need to contain Altitude ..
I'm a pilot and would love to plot hight / speed etc in 3d ..
DO you know any SW ? How to turn Altitude recording on etc ?
Thanks .. Peter
lbendlin
PostPosted: Mon Dec 27, 2004 9:22 pm    Post subject: Reply with quote
Altitude, uhm... the eternal step child...
For starters, be always aware that altitude information is not very reliable - the VDOP is very high. It improves when you use DGPS, but don't rely on it.
To make matters worse, some SiRF chipsets calculate the altitude offset from the geoid model the wrong way around, and some don't calculate it at all.
Then, verify your Trine's documentation and check that it actually records altitude. I am using a DeLorme BlueLogger (aka Leadtek 9537) which DOES record altitude.
Lutz
pwwuk
PostPosted: Thu Dec 30, 2004 4:30 pm    Post subject: Reply with quote
Umm .. perhaps this was not so stuid .. I sawa guy with a garmin uses to plot his sky dives in 3d , I had hoped to do similar with the Trine ..
Can you move this chat to a better place so that I can get help without hogging your time !!
The documentation http://www.emtac.com/download/CRUX_LOG%20manual.pdf claims that ALT is in the log ..
However I get this as a log ..
Datum,WGS84,WGS84,0,0,0,0,0
TP,D, 053.725503000, -02.540325000, 12/25/2004,15:07:24,1
TP,D, 053.725493000, -02.-54032000, 12/25/2004,15:07:25,0
TP,D, 053.725449000, -02.-54022000, 12/25/2004,15:07:43,0
TP,D, 053.725458000, -02.-54021000, 12/25/2004,15:07:44,0
TP,D, 053.725466000, -02.-54020000, 12/25/2004,15:07:45,0
lbendlin
PostPosted: Thu Dec 30, 2004 4:41 pm    Post subject: Reply with quote
Can you confirm that you have the firmware shown in the manual? Your data log looks very different from what they show. Why don't you give Emtac support a buzz?
Lutz
pwwuk
PostPosted: Sat Jan 01, 2005 2:46 pm    Post subject: Reply with quote
I emaled them a couple of days before this post !
No metion of FW Rev in docs nor on site that I can see.
The unit is new ..
With EGNOS I seem to get very good alt data, cant be the only person in the world trying to get in the log and then view in 3d some how ??
Thanks for all your help // Any ideas ?
DavidW
PostPosted: Sat Jan 01, 2005 8:14 pm    Post subject: Reply with quote
I'd be surprised if you were picking up an EGNOS signal in the UK at present; unless things have changed very recently, the only satellite transmitting ETSB (EGNOS test signal) data is PRN131, which is very low to the horizon in the UK.
It's possible you'll pick up PRN131 when airborne - but it's far more likely you're picking up PRN122, which is a WAAS satellite. PRN122 does have some information that will help a bit in Europe, but WAAS doesn't contain wide area differential correction information for Europe.
Meanwhile, the problems that Lutz mentioned only come into play if you are interested in absolute altitude - though they are very real for SiRF based GPSes.
If all you're interested in is your relative altitude during a skydive (or even during a flight, when it should be obvious from the data when you're on the ground), you can easily correct the figures so that when you're at rest you're on the ground.
