tonyg Occasional Visitor
Posted: Sun Dec 26, 2004 11:47 pm Post subject: using bluetooth tomtom gps on laptop via fugawi mapping soft |
Hi all, merry christmas,
I have a problem using bluetooth tomtom gps on laptop via fugawi mapping softare.
Has anyone done this? is it possible?
I have tried to get the bluetooth tomtom gps to work on the laptop with fugawi, every time i try to configure fugawi to use the gps it comes back with a error message "port \.\\com13 is busy" i have checked settings in device manager and set the appropiate settings in fugawi.
Any ideas, please help
Tony |
lbendlin Pocket GPS Staff
Posted: Mon Dec 27, 2004 4:16 pm Post subject: |
Before you try Fugawi use a test tool like VisualGPS to verify the function of the receiver and the connection.
Also, COM13 is a tad high. Try to cleanup your PC a bit and remove unneded BT services so you can get the outgoing COM port below COM10. If necesary, completely remove and re-install the BT stack. _________________ Lutz
TomTom/TeleAtlas NAVTEQ |
Posted: Mon Dec 27, 2004 10:46 pm Post subject: |
Thank you for your reply,
I am now using com6 and have installed visual gps, but still get the same error message or a variation of it, "access denied com port in use" the only service using com 6 is tomtom gps bluetooth the device i want to connect to. if i select within bluetooth settings "tell me about bluetooth wanting to connect" it asks me for a pass key, via a wizard if i cancel, as tomtom does not use a passkey "i think?", it freezes up and after a minute or so gives the same message above. |
Posted: Tue Dec 28, 2004 12:04 am Post subject: |
Please be aware that it's not the TomTom GPS using the service of COM6, but rather the other way round - your local (outgoing) port COM 6 is using the serial port profile service of the BT GPS.
Are you successful in browsing for BT devices and discovering the services that the TomTom has to offer? _________________ Lutz
Posted: Tue Dec 28, 2004 12:42 am Post subject: |
when asked for a passkey by the bluetooth connection wizard i entered 0000 (supplied by your self in the tom tom forum) and visual gps is working now and "amazingly" so is fugawi:) HORRAY!!
Thanks again for your time, and advise |
