Jackie Occasional Visitor
Joined: Dec 25, 2004 Posts: 14 Location: Portland, OR
Posted: Sun Dec 26, 2004 8:59 pm Post subject: iPAQ rx3715 + Navigator USA 2.24: "GPS position unrelia |
Okay, I'm about to throw this whole system out the window, but let's see if anyone knows what the issue is here.
Problem: Can't get my iPAQ rx3715 to get a GPS reading. Ever. I've never gotten past "GPS position unreliable."
The equipment I'm working with:
a. TT wireless GPS receiver (Bluetooth)
b. TT Navigator USA (v. 2.24)
c. HP iPAQ rx3715
The reciever appears to have a fix (green light is blinking).
BT connection is made (blue indicator light illuminates).
But I have YET to get past "gps position unreliable" or see any connections to satellites. The "gps status" screen has yet to be anything but greyed out.
Please help, as I'm planning to return this whole mess on Monday if I can't get a solution. Been troubleshooting for 3 days straight and it's ridiculous.
Thanks! |
alix776 Pocket GPS Moderator
Posted: Sun Dec 26, 2004 9:08 pm Post subject: |
have you left the gps receiver in a clear veiw of the sky for around 30mins(say in the car or on a window ledge) before using it so it can get a proper fix then each time after that you should get a fix with in a few seconds of turning the unit on. If you cant get a fix in the car at all place the unit on the top of the car roof (while sationary) to see if you get a better fix as you may have an athermic windscreen and it may be better mounting the receiver in the back of the car or getting an external aireial also if your not on or near a road you will get a postion unreliable _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
device Lumia 950 xl |
lbendlin Pocket GPS Staff
Posted: Sun Dec 26, 2004 10:14 pm Post subject: |
Jackie,
can you please report which version of the TomTom GPS driver you are using.
Also, in your BlueTooth settings, what is listed as the Outgoing COM port? _________________ Lutz
TomTom/TeleAtlas NAVTEQ |
Posted: Sun Dec 26, 2004 11:23 pm Post subject: |
lbendlin wrote: | Jackie,
Also, in your BlueTooth settings, what is listed as the Outgoing COM port? |
Thanks for your speedy reply.
I've been looking for the gps version but don't know where to find it. Can you tell me?
The outgoing COM port says 6. Then there's a check mark next to the paragraph: "Default device for outgoing serial connections: TomTom Wireless GPS. Display the device selection screen the next time an outgoing serial connection is attempted."
Don't know what that means either. ![Crying or Very sad](modules/Forums/images/smiles/icon_cry.gif) |
Posted: Sun Dec 26, 2004 11:25 pm Post subject: |
alix776 wrote: | have you left the gps receiver in a clear veiw of the sky for around 30mins(say in the car or on a window ledge) before using it so it can get a proper fix then each time after that you should get a fix with in a few seconds of turning the unit on. If you cant get a fix in the car at all place the unit on the top of the car roof (while sationary) to see if you get a better fix as you may have an athermic windscreen and it may be better mounting the receiver in the back of the car or getting an external aireial also if your not on or near a road you will get a postion unreliable |
Yes, it's been sitting in the window, happily blinking, for days. I had it outside for about an hour... I've tried all sorts of places. According to the indicator light, which is blinking green, I am getting a fix.
Is that wrong? |
Posted: Sun Dec 26, 2004 11:33 pm Post subject: |
if its a wireless receiver let it totally discharge and then recharge it it should work after that _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
Posted: Sun Dec 26, 2004 11:37 pm Post subject: |
alix776 wrote: | if its a wireless receiver let it totally discharge and then recharge it it should work after that |
Yes, it's wireless.
I tried that yesterday. I recharged it while it was on. Maybe I should recharge it while it's off? |
Posted: Mon Dec 27, 2004 12:46 am Post subject: |
you find the GPS driver version by tapping Start > Settings > System > GPS > GPS.
You possibly have a "bad" TomTom GPS driver that is redirecting the COM port. _________________ Lutz
Posted: Mon Dec 27, 2004 1:01 am Post subject: |
lbendlin wrote: | you find the GPS driver version by tapping Start > Settings > System > GPS > GPS.
You possibly have a "bad" TomTom GPS driver that is redirecting the COM port. |
Ah, there it is. I have v. 2.09 302/393.
:D |
Posted: Mon Dec 27, 2004 1:23 am Post subject: |
in the gps screen what com port are you using.
in the bottom drop down box is where you select the com port try selecting bluetooth gps the last option in the drop down box _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
Posted: Mon Dec 27, 2004 1:53 am Post subject: |
alix776 wrote: | in the gps screen what com port are you using.
in the bottom drop down box is where you select the com port try selecting bluetooth gps the last option in the drop down box |
I've tried every option, including all of the bluetooth configurations.
Nothing.
It's a sad day. ![Crying or Very sad](modules/Forums/images/smiles/icon_cry.gif) |
Posted: Mon Dec 27, 2004 4:05 pm Post subject: |
2.09 is a very bad version. Please completely uninstall this GPS driver and re-install version 2.07 from our downloads page. _________________ Lutz
Posted: Mon Dec 27, 2004 6:38 pm Post subject: |
lbendlin wrote: | 2.09 is a very bad version. Please completely uninstall this GPS driver and re-install version 2.07 from our downloads page. |
Unfortunately, 2.07 wreaks havoc with my pda. Everything now hangs or crashes.
Ugh.
What next, coach?
Thank you for your efforts on this. |
Posted: Mon Dec 27, 2004 6:44 pm Post subject: |
it shouldnt i know david w uses 2.07 on his 4700 have turn the recieve all in coming beams off _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
Posted: Mon Dec 27, 2004 7:06 pm Post subject: |
alix776 wrote: | it shouldnt i know david w uses 2.07 on his 4700 have turn the recieve all in coming beams off |
I'm not on a 4700. I'm using an iPAQ rx3715. Twice now I've installed 2.07 and everything comes to a crashing halt.
I'm going to start looking at a plan "b" for gps. This is way too irritating and complicated.
Thanks for trying. |
