Pocket GPS World :: View topic - Ipaq 3630 TomTom V3 & Navman 3400 Voice Jacket...how???
lbendlin
PostPosted: Mon Dec 20, 2004 8:19 pm    Post subject: Reply with quote
can you confirm that TomTom GPS is really removed?
Lutz
TomTom/TeleAtlas NAVTEQ
Martyn
PostPosted: Mon Dec 20, 2004 8:20 pm    Post subject: Reply with quote
Yes I did a hard reset & started again
Martyn
lbendlin
PostPosted: Mon Dec 20, 2004 8:45 pm    Post subject: Reply with quote
I have a similiar jacket, and it works as COM4 at 4800 without problems. (Mine just doesn't use a driver).. Can you try other ports? Maybe it's at COM5 on your machine.
Lutz
Martyn
PostPosted: Mon Dec 20, 2004 8:50 pm    Post subject: Reply with quote
What do you select as the GPS in TOMTOM though?
Martyn
PostPosted: Mon Dec 20, 2004 8:52 pm    Post subject: Reply with quote
If I select aan NMEA GPS, I can only select
Com3 (Hangs Machine Up)
IRDA
Serial Cable Com1
Serial USB
If I select a Navman GPS it automaitcally defaults to GPS Reciever (used to say com4 with newer TomTom Driver)
lbendlin
PostPosted: Mon Dec 20, 2004 8:56 pm    Post subject: Reply with quote
Again, you need to keep TomTom out of the picture until the GPS actually works. You should do a hard reset, then install the appropriate Navman jacket driver and Crux_View - nothing else.
Have a look here - according to this article the GPS is on COM6 at 57600 . That's very different from the jacket I have, but please try.
http://www.pocketgpsworld.com/navman3400review.php
Lutz
Martyn
PostPosted: Mon Dec 20, 2004 9:03 pm    Post subject: Reply with quote
Ok...
Hard Reset
Installed Navman Driver 3.11
Installed Crux View
Select Com2 & then Select Open = COM PORT Can't Open!!
Select Com3 & then Select Open = Read Error!!
Select Com4 & then Select Open = COM PORT Can't Open!!
Select Com5 & then Select Open = COM PORT Can't Open!!
Select Com6 & then Select Open = COM PORT Can't Open!!
Select Com7 & then Select Open = COM PORT Can't Open!!
Select Com8 & then Select Open = COM PORT Can't Open!!
Select Com9 & then Select Open = Read Error!!
Martyn
Tim Buxton
PostPosted: Mon Dec 20, 2004 9:11 pm    Post subject: Reply with quote
3.16 is the correct one for the Navman 3000/3400 Jacket. It isn't a Compaq iNS jacket, is it?
Tim
Martyn
PostPosted: Mon Dec 20, 2004 9:12 pm    Post subject: Reply with quote
Ok!! Making Some Progress (ish)
Did exactly as before (Hard Reset etc) then loaded 3.16 Navman Serial Driver Instead. It now seems to work!! (Only if I select Baud Rate of 57600 (All other settings will just give a Baud Rate Error
Martyn
Tim Buxton
PostPosted: Mon Dec 20, 2004 9:17 pm    Post subject: Reply with quote
57,600 is the corret baud setting, too. You are making progress, it would appear.
Tim
lbendlin
PostPosted: Mon Dec 20, 2004 9:19 pm    Post subject: Reply with quote
OK, so keep the receiver at COM6 57600, install TomTom and the voice files BUT DO NOT INSTALL TOMTOM GPS 3.xx!!! Install TomTom GPS 2.07 from our downloads page instead.
Lutz
Martyn
PostPosted: Mon Dec 20, 2004 9:28 pm    Post subject: Reply with quote
ok...just as I am getting close I have to go to work :-(
I will post later my findings.............
I cannot tell you how great you have all been!
This has to be one of the best forums I have ever joined!
Thankyou
Martyn
Martyn
PostPosted: Wed Dec 22, 2004 7:42 pm    Post subject: Reply with quote
Hiya Guys...
I have installed TomTom & unfortunately I cannot get TomTom to secure a gps position. Does anyone know for sure what GPS device I should select in the TomTom GPS software?
I know that the gps is working from using Crux View.
Again....an help is greatly appreciated
Merry Xmas All!
lbendlin
PostPosted: Wed Dec 22, 2004 7:52 pm    Post subject: Reply with quote
Same as stated above - set it to Standard NMEA 57600 at COM6. Do not attempt to select a particular GPS device.
Lutz
Martyn
PostPosted: Wed Dec 22, 2004 11:41 pm    Post subject: Reply with quote
I cannot select Com 6 though in tomtom, I can only select Navman Driver or other ports that are not the Navman Jacket
Page 2 of 3
22.105 (30 Oct 24)
