Pocket GPS World :: View topic - Need cable advice: Garmin eTrex <-> iPaq 4150
tiwas
PostPosted: Mon Dec 20, 2004 12:13 pm    Post subject: Need cable advice: Garmin eTrex <-> iPaq 4150 Reply with quote
Hey all!
Anyone know which cable I should get in order to use my etrex to feed signal to my ipaq? I would prefer a cable that charges the ipaq if possible.
Instructions on building it myself, or where to get a premade cable is fine.
Cheers!
lbendlin
PostPosted: Mon Dec 20, 2004 1:09 pm    Post subject: Reply with quote
You need to upgrade the 4150 to the latest ROM so it recognizes the COM1 port at the connector.
Then you need the 22 pin connector assembly - can be bought at ipaqrepair.com or other hardware shops. for example here http://www.gomadic.com/ip4leadprewc.html
I assume you do have the serial cable for the Garmin.
You can power the whole setup from a Y-cable that gets delivered with any of the serial GPS receivers. The only caveat is that normally these Y=cables come with a GPS receiver attached, so you would end up with two receivers ;-)
You can also adjust a standard iPAQ car charger to merge into the 22 pin cable.
Lutz
TomTom/TeleAtlas NAVTEQ
Pc-Mobile
PostPosted: Mon Dec 20, 2004 2:37 pm    Post subject: Reply with quote
GPEQ38 connects then and include car power for Ipaq (GPS must use batteries).
http://pc-mobile.net/gedc.htm
If you can wait a little longer (only DAYS from now) we will be releasing a bluetooth adapter for Garmin/Magellan GPS which allows your Garmin/Magellan GPS to be connected to PDA via bluetooth.
Pc-Mobile
http://pc-mobile.net/gps.htm
22.064 (26 Jun 24)
