Pocket GPS World :: View topic - Using PiN with other software
AusS2000
PostPosted: Thu Dec 16, 2004 11:04 am    Post subject: Using PiN with other software Reply with quote
As the PiN is a Mitac Mio 168 what is required to run other software with it?
I would like to use it as a general GPS with software like GPSDash (for example). I'm running the software but it doesn't seem to see the GPS (Com2, 4800). Any ideas?
PostPosted: Thu Dec 16, 2004 11:17 am    Post subject: Reply with quote
This should work out of the box. Are you sure there is no other program running in th background? Do you hae TomTom Navigator installed?
AusS2000
PostPosted: Thu Dec 16, 2004 11:24 am    Post subject: Reply with quote
It uses SmartST but it's not running at the same time.
I'll try again and see what it does.
icsys
PostPosted: Thu Dec 16, 2004 1:17 pm    Post subject: Reply with quote
You will need to make sure that SmartST is not running as only one application can use the GPS data at a time, unless you use a utility such as GpsGate which allows you to share the GPS data with several applications on a virtual COM port.
Ian.
Navman iCN 635
TomTom GO
Anquet OS mapping
AusS2000
PostPosted: Thu Dec 16, 2004 10:38 pm    Post subject: Reply with quote
Had another try. Wathcing the 'Data' paletteI see a lot of timeouts, but also plenty of GPS data (including the correct co-ordinates for my location).
But none of the dash screens show anything meaningful.
PostPosted: Thu Dec 16, 2004 11:57 pm    Post subject: Reply with quote
Is trickle mode enabled? maybe a factory reset of the GPS is in order.
AusS2000
PostPosted: Fri Dec 17, 2004 12:02 am    Post subject: Reply with quote
Where is 'Trickle Mode' set?
I'll try a basic reset, then a full factory one and see what happens.
AusS2000
PostPosted: Fri Dec 17, 2004 12:50 am    Post subject: Reply with quote
Here's some screen shots.
This is the type of data I'm seeing:
And if I scroll across I see my co-ordinates:
Mind you, I bring the unit inside and it keeps scrolling this data. Does the GPS keep sending the same data if it doesn't get new data? This whole GPS thing is a bit new to me.
PostPosted: Fri Dec 17, 2004 10:28 pm    Post subject: Reply with quote
Timeouts will occur if you don't have a good view of the sky. Any GPS application will work with the Mio 168, PiN 100 and PiN 300 as I have half a dozen other utils working on these without problem.
You need to set the app to use COM2 NMEA 9600 as this is what the GPS Receiver is configured to.
AusS2000
PostPosted: Sat Dec 18, 2004 12:33 am    Post subject: Reply with quote
Really! Everything I've seen (including the SmartST manual) says it's 4800.
PostPosted: Sat Dec 18, 2004 8:50 am    Post subject: Reply with quote
It depends, checking one of the Mio's last night it's set at 9600 and I haven't changed the baud rate, but another one is running at 4800. It really depends on what baud rate yours is set at. If 4800 isn't working then I'd try 9600.
22.094 (25 Sep 24)
